BuckeyeR/T
- Oct 14, 2006
- 347
So, will clay alone strip wax/sealant ?
Is it possible to remove wax, but not sealant? If so how would that process go about. Or should I not worry so much about applying a sealant AND wax but be more vigelant with the wax?
You found it in Griots. Why would you care if it fills or not? If you polished and did an IPA wipe down it will show the true finish. If it's perfect, a filler will do no harm. If it's not perfect the fillers will help hide the imperfections. You win either way.Gritos Garage makes a paint prep product that will get you back down to just the paint. I am thinking about pulling the trigger on it but not sure if its worth the money. I too am on a quest to find the perfect NON FILLING NON ABRADING pre wax cleaner.
Chris
You are probably thinking about CG Citrus Wash Shampooi am not sure why some of you are posting the citrus wash clear from CG...it is specifically forumlated to NOT strip wax or sealants
What about Meguiar's Body Solvent??? Does it need to be rinsed afterwards?
Here's the direction at the bottom of their page for using it as a paint cleanser.i am not sure why some of you are posting the citrus wash clear from CG...it is specifically forumlated to NOT strip wax or sealants
I can't find this on their website?
The thing is, and I've tested this rather extensively, there is no chemical wash that effectively strips modern sealants. What I mean is, there is nothing you can put on your bucket to strip a sealant that is healthy and was applied correctly.
Directions For Use::
[*]Extremely concentrated and highly versatile 1 cap full with 3-5 gallons of water for a superior wash.
[*]As a paintwork cleanser dilute
1oz with 1 gallon water for superior surface cleaner to remove built up grime and leftover wax.
[*]Always start by washing the tires and
wheels first.
[*]Don't use the same wash water on your car's paint as you do your tires and wheels.
[*]Always wash vehicle when the
surface is cool.
[*]Rinse the vehicle with water to remove loose grit and surface dirt.
[*]Start washing from the top down and rinse the car
often.
[*]Frequent rinsing is important if you are washing on a warm day.
[*]Do not allow the soapy water to dry on your paint.
[*]Use a final rinse of free-flowing water (nozzle off the hose) allowing the water to sheet
The vehicles get clayed every three months. When I'm done I take a water hose and run water over the hood so I can see what kind of water bubbles are present.
I use two products: Polish shines and a good premium paste wax protects. Prior to applying those two products I do the 'ol 2x2x2x2 test area if I see any minute scratches or swirls that are produced when you remove the above two products.
The "only" sealant I use on my vehicles is detail spray and that is on the front of every vehicle. Apply, wait one minute, wipe off. You do get a nice shine but more importantly I use this product because bugs normally spray right off as soon as I get back home. I also take this with me on trips so again I can remove all the bugs.
Does the clay take the sealant off? No, not all of it but that's okay because more will be sprayed back on the vehicle. Clay does remove the polish and paste wax.
After buffing the test section and once I get the swirls or scratches removed, I then buff the entire vehicle. And yes, there are times I will only do a hand detail. It can't be avoided but when you are removing scratches/swirls, that is the only time I will ever put a M/Fiber towel to the surface of any vehicle.
It's probably over kill and more time consuming but I "always" foam all three vehicles down "twice." Water rinse with pressure washer, first application of the foam, another water rinse and then the second application of foam and again, water rinse.
Does this strip wax or sealants? No! However it will thoroughly clean all abrasive contaminants away from your paint. It is a concentrated product ~ 1/2 oz to 2 gallons of water.
I am a firm believer that the less you touch your paint with any cloth (Microfiber drying towels) the more minute swirls/scratches you have to contend with.
just repolish it... the polish will easily strip the LSP
