Strongest cleaner that won't mar plastic
YankeeFan
Noticed an unsmooth area on the driver side door from placing my arm on it as I am driving. DP Interior Cleaner took some off but nervous multiple applications will dull the plastic. What is strong but safe to use?
Thanks,
Howard
1Z Einzett deep plastic cleaner works for really dirty plastics I have come across. OPC that InDetail mentioned should work great too
I like using P21S GEPL for cleaning plastics. It can pull a lot of dirt off of trim that appears clean.
This! Just be sure to rinse thoroughly after using either one. I use two passes with a MF towel just dampened with water followed by a dry towel.
Please disregard my previous post earlier. Was meant to go in another thread :doh: . I wouldnt want you to use a paint cleaner inside your car
