Suade and adhesive, need help!
AJS
Hey all was installing a black suade headliner fabric with a light foam backing on a door panel. Applied too much contact cement and some seeped through making 5-7 small spots. Anyway to remove the cement? Wait till it dries or do something immediate? TIA hopefully can fix this
That's a problem maybe some afta if you can get it locally.
Yeah, it was hand cut and hand fit. Took several hours to complete.
Afta? So far from what i've seen online, adhesive remover like 3m, acetone, and a hear gun are my options
Afta is a drycleaner product,can be suited as a adhesive remover like the products you mentioned.can you spot repair aerosol black paint.Your in a tough spot here.
Can you take a razor blade and use the tip to crush the cement with some pressure.
Oh Okay. Worse came to worse I could always redo it. Not sure how my adhesive will work/if i'll have to get back and redo these again. Definitely open to anyones ideas with this. I have spare fabric, I think i'll recreate the problem on the scraps and try some trouble shooting/test your methods. Its recently dried (put on maybe 4-5 hours ago)
