Sun Joe SPX3001 Pressure Washer?
What do you guys think of these Sun Joe power washers? Great PSI and GPM!
https://www.amazon.com/Joe-SPX3001-Electric-Pressure-Washer/dp/B00LX8Z03K
Will the Auto Geek foam cannon work with this?
I have the SPX3000, it works great with a foam canon. I get a lot of thick foam.
The only issue is it comes with a 25 ft. hose and I had to constantly move it to get around bigger vehicles. I bought the 25' extension hose and the pressure did drop slightly. Not sure exactly but I did notice its not as strong and the foam is slightly less. Still not a huge deal though.
The AS390SS seems very nice as well..it is the highest rated over on pressurewashersdirect.com
I have one and love it. Swap out the cheap plastic fittings, and you're set. For the record, I have a cheapy Amazon 20.00 foam cannon, and it works great
Does Amazon $20 foam cannon work with brand new Sun Joe SPX3001 out the box? From my understanding, the Sun Joe doesn't use standard fittings and I'm thinking the Amazon cannon has a standard fitting? Thanks so much for the help.
I have the new SPX3500 model. Much better than the old models. Brushless motor and Standard fittings are nice. Very quiet also. I bought an extra 25’ of the hose. 50’ total.
Ok cool! I'll look that one up...thanks!
For Foam cannon, GPM more functional than PSI.
generally I believe > 1.75GPM works nicely for Foam Cannon
"SPX3500 2300-PSI 1.48 GPM Brushless Induction Electric Pressure Washer w/Brass Hose Connector"
