Eldorado2k
- Nov 9, 2015
- 14,544
- 644
Sounds like you need a California Car Duster (oh the horror!). I'm gonna get hammered for this... but imo a piece of yarn dragging a dust particle isn't going to scratch clear coat. When used properly, they work great. No, you don't lay it on the surface under its own weight and rub it back and forth several times. You hold it about 4" above the surface so just the tips of the "yarn" are in contact with the paint. You slowly move the tips across the surface and any dust on your vehicle will be removed. Mostly a non issue on vertical panels.
Can you "wash" your car with a California Car Duster? Of course not. But when used correctly, it's less damaging than a wash mitt during a 2 bucket method wash. But when it's slightly dusty between washes I think it's actually more gentle than a 2bm car wash. Just my opinion![]()
California Dusters are meant to be used to remove dust that has accumulated while parked in the garage. IMO trying to dust off any kind of dust/dirt that happened outdoors is asking for bad results & swirls.
Safer than a bucket wash? You’d be rinsing all the dust off prior to the wash instead of tediously wiping it off with the duster.. How could the duster be safer?
