Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Surgical Precision Buffing Tools
Here's a few tools for surgical precision buffing. I define surgical precision buffing as a way of using smaller pads, smaller backing plates, extensions on your rotary buffer and a lightweight, compact rotary buffer.
Using these smaller pads on a easy to hold and maneuver compact rotary buffer makes buffing out tight areas, thin panels, intricate designs, motorcycles, miscellaneous painted components like rear view mirrors, spoilers, windshield frames, a-pillars, etc. a lot easier and safer.
Going small...
Flexible 3" backing plate
Short pile length PFW pads...
Rotary Buffer Extensions
Cyclo wool pads
These are made for the Cyclo Polisher but I've used them successfully on rotary buffers. You can also use the Cyclo foam pads on rotary buffers as well as other tools.
4" Lake Country Wool Cutting Pad
The back of this style has a flexible plastic liner to prevent the fibers for the pad from bending back potentially allowing the backing plate to buff into the paint.
See how it fits around the outer edge of the backing plate...
Purple Foamed Wool Pads
Below is the new thin PFW on top of the original PFW which as you can see, the new pads is very thin, this means it should work exceedingly well on DA Polishers and the original version is very thick.
And sometimes I like to use the extensions with larger backing plates and pads too...
The above isn't a complete collection of everything we have at Autogeek for surgical precision buffing but you get the idea...
As I can, I'll take more pictures of more cool tools and add them to this thread...
Going small...
Cyclo wool pads
Extensions for Dual Action Polishers?
There are no extensions for other tools, thought I would add this because the question gets asked all the time. You don't want to try to use an extension on any type of dual action polisher, it's not going to work.
