Just top of fender, needed to regroup before going any further. What is SSR?
SSR is the generic name for the PB products of Super Swirl Remover.
Using Lake County Pad colors
If you went SSR2.5 with an orange pad, you were way too aggressive with the pad selection. PB does not recommend an orange pad with any of the SSR line that I recall, but I did not track the info on SSR3 ( Steve calls it liquid sandpaper ).
The most aggressive pad you should be using with SSR2.5 is a white pad. I have seen some use green, but this is someone that is well versed and experienced in PB product usage on different paint types.
For the SSR2 & SSR1 it is recommended that only black, blue or red ( finishing ) pads be used.
I did SSR2 with an orange flat LC pad on my PC on a Corian top, and got what I have read is called pig tails.
The cartoon curly tail marks in the top. Here I was trying to remove a few scratches, and I caused myself to need to wet sand and start over or try again with SIP. This is with a tool that is considered weak when compared to the Flex, so i can imagine that with the forced rotation on the flex you could make a big mess in short order.
This is in part of why I went on a quest to figure out what I am doing, less I trash a car. I am just happy that I went off the reservation on something that is the same color all the way through, not someone's car.
For the ProPolish and ProPolish2, these are not mechanical polished like the SSR line, they are all chemical.
You can get fairly far with ProPolish by changing the pad out.
Current thought is you have a soft clear coat.
The concept is always the same, least aggressive first and work up if more correction is needed ( I got this from tuscarora dave and every other seasoned member here - sage advice )
If you go with PP, start with a finishing pad on a test section.
Once you are done, clean it off and see what you have.
With the thought that you have a soft clear coat, be careful about using 15% IPA to wipe down the panel. Not my opinion, but from what I have read this is bad to use on soft paint. I just read a thread here tonight about IPA wipe downs, and 2 manufactures make something that serves the same task of cleaning every thing off the paint post polish, to know if you got the job done. Menz is one, I forget the other. Just something to keep in mind.
Now the big question, did the Klasse fix the defects on the camaro??
You won't know until you can get the Klasse off the paint and see.
The truck, needing PP2 is a question of what you are trying to correct on it.
Are there major defects or just a bit of marring ? My limited opinion, go with ProPolish with a finishing pad. If the paint is in good shape, go with a blue or red pad and keep in mind, ProPolish is not mechanical like the SSR line. If it is mild defect or swirls, start with a black pad and see what happens.
If you can get a close up of the paint defects that you are working on, tuscarora dave or another well versed member can give you a better starting point than try x with y pad. Also the make and year ( and color if the picture does not show it well ) will help someone with extended experience.
They might know how the clear is on a given manufacture and what to expect. This is info I do not have.
