Switching to Menzerna...
ObsessiveAutoDetail
This is in NO way a hit on Meguiars 105/205. Been using it for a while now. And while it produces phenomenal results with a DA polisher, it's working time with a rotary leaves something to be desired. Which Menzerna polishes should I look in to to replace the 105/205 combo when I'm using my rotary?
Thanks!
If I had to recommend 3 polishes from the Menzerna line it would be the bundle below.
This is a killer trio that will cure just about anything thrown at them.
Menzerna Power Gloss, Power Finish & Super Finish Bundle, Menzerna Polishes Combo, Nano Polish, Power Finish Polish, Power Gloss Compound
This is how they compare from a cut and gloss perspective.
Id go with Fast Gloss, it's a step above powergloss and finishes down very nice.. I've used it a few times with my da and its almost get away with a 2step..
Fast Gloss (S500) is not available in the states due to the high VOC.
And yes, S500 is a killer and pair it with PO203s and PO106FA and you have a winning team.
I have a few Menz polishes, never needed Powergloss. I use SIP and 85RD.
SIP, nano(PO106FA) and PO85RD are awesome polishes. I also keep power finish around for one step.
Thanks!
i have switched to menzerna super intensive polish and found it cuts much better than megs 105 with a pcxp, especially on hard clear coats. i took the advice that bobby gave you.
I still find the ceramiclear polishes from Menzerna all that !
I'm a huge Menz fan. Never a bad experience. You'll love 'em!
