dnoraker
- Apr 19, 2010
- 262
I swear that lately I've been having a much harder time taping off a car. It simply won't stick. Same 3M blue tape, plus I've tried some other green painters tape I found at the home improvement store that was a little cheaper, but had the same problem. So, I just got some 3M automotive tape. Exactly the same problem.
I'm taping after doing claying the car, and I suspect that the clay lube (Megs Last Touch) is the problem. I used a little isopropyl alcohol, which helped with the chrome trim pieces, but marred the heck out of the single stage paint ('77 Buick Regal) using a Megs microfiber. I've had this problem before with marring using IPA and a microfiber, but not this bad.
So, since this is a paint prep problem, how do I prep the surfaces to be taped without marring them? Or, how do I change my process so I don't have to prep the surface? The wierd part is that I haven't changed my claying procedure or products in a few years.
I have a lot of stuff to tape off, so I would totally appreciate any help on this!!!!
