Excessive Detail
- Apr 16, 2006
- 1,166
Hey guyz, tell me what you think of the this washing technique I've been using:
1. Spray a simple green solution of 1/30 on all lower panels of car, fenderwells, wheels(depending which type), and front bumper(wear all those lovely bugs wind up).
2.Using foam gun cover entire car with foam(acting as a presoak), then completely rinse using just running water.
3.Use two bucket method, with a grit guard in the rinsing bucket.
4.Use a MF mitt or sheepskin mitt to wash with.
4.Before washing each panel, thoroughly soak panel with foam then wash, rinse and agitate mitt in rinsing bucket.
5.Once each panel is washed and rinsed, then move onto the wheels.
6. one final rinse down, still just using running water.
7. Dry with waffle weave towel, Ex: guzzler, then wipe down with qd and mf.
I know most of you foam down each panel in front of you mitt as you go, but do you think just completely soaking the panel with foam is good enough?
Between a mf mitt and a sheepskin mitt, which would you go with?
Also, I was detailing a car today and when I clayed it, well lets just say I have never seen that much stuff on the clay after each panel, it was freakin dirty, I kept reforming the clay after each panel, which lead me to this question, how do you know when its time to ditch the clay, I used half of a dp clay bar, should I use the whole thing next time or is half okay?
Thanks guyz.
Thanks guyz.
