The 9 wax showdown!
A bit of a surprise for everyone. I was at Kragen buying some winshield wipers, and I saw a bottle of Dupont Teflon wax on clearance for $1.50 so I thought why not. To say the least I am a bit surprised! This stuff is VERY easy on, but tends to be a bit hard to remove, so apply it thin. It more or less reminds me of Eagle One Nanowax in terms of application and removal if that helps. Now, when it comes to its shine, that is what surprised me! I put it side by side NXT V2 and believe it or not, it looked almost EXACTLY the same! Upon further inspection, it did not cover up as many swirls as NXT, but the darkening effect is right there with it and NanoWax. Sheeting is also VERY good, and again right there with NXT and NanoWax, probably mostly due to the fact that it does leave the surface pretty slick (about the same as NXT V2).
So, guys, I HIGHLY recommend going to Kragen and seeing if you can get some for clearance, because it is without a doubt, worth every penny of that $1.50!
Has anyone tried using Autoglym high definition wax yet,if so how does it compare with some of the other hig end waxes?
