LegacyGT
- Aug 13, 2010
- 2,090
So I called up one of my friends and arranged to pick up his car to give it a full detail for his birthday, and give me an opportunity to test out a new Beta Nano Polish not currently available to the public. This car has been featured in a few of my other reviews as the 'abused vehicle' ... it is 11 years old and has never seen a detail or even wax let alone regular washing. Perfect!
000.- Products Used
Flex PE-14 Rotary
Flex 3401 VRG DA
LC Hydro Tech Cyan & Tangerine pads
LC Red wax pad
Menzeran SIP
Menzerna Power Gloss
Beta Nano Polish
Iron X
Tar X
OPC 3:1
Mothers Yellow Clay
Optimum Car Wash Concentrate
MF wash mitt
2 Bucket Method w/ GG
Mothers Long Handle Tire Brush
Daytona Speed Master Brushes
1'' brush
Master Blaster
Griots Paint Prep
DP Gloss Tire Gel
Ultima Trim and Tire Guard
Fenix Headlamp
Cobra Micro fiber towels
Other Micro Fiber towels
Stoners Invisible Glass
DP Poli-Coat Sealant
00.- Pictures- Pictures were adjusted for white balance, cropped, and some cases exposure adjustments made. All adjustments were made to the entire photo, and no selective editing was made.
0.- Conditions
The car was in bad shape, the paint had no luster, and there was heavy over spray over the entire car. Don't confuse the white dots of paint with metallic flake ... though we do discover the metallic later.
The condition of the vehicle before I began working:
Truly flat looking paint, basically looks steel grey.
Washing the vehicle I only found 2 spots on the paint that beaded any water ... I thought they were bird bombs at first, but they turned out to be globs of grease. They cleaned up easily with some OPC 3:1 and a MF. To wash the vehicle, I rinsed the entire surface, then soaked in OPC 3:1 before washing with Optimum Car wash Concentrate and a MF mitt.
1.- Wash & Iron X
I began the detail at night which I actually prefer because it allows me to break up the detail. In the evening I do the initial wash, paint decontamination, and clay then I get some sleep and wake up in the morning to polish out and finish the paint. Working at night requires some extra tools, in addition to my dual 500 watt halogens, I have an excellent Fenix head lamp (285 lumen) and a hand held flashlight of similar power that Heath helped me out with.
Time to decontaminate the paint! I began with the Iron-X, and this was my first application using Iron-X so I was excited to see it work. From opening the cap to insert the sprayer I can tell you this stuff was strong so I decided to use my respirator while using it. I also discovered the 1 downside to my beard ... my respirator no longer makes a perfect seal
but by using one hand to hold it tight and the other to spray with it did it's job quite well, and I didn't smell a thing while using the Iron X.
I was not sure that I would be able to see the Iron X doing its job in the dark, but I was pleasantly surprised after a minute or two of waiting:
The Iron X did its job nicely, and Car Pro is quickly becoming one of my go-to lines much like Optimum and Ultima are.
2.- Clay and over spray removal
Claying was one of the more time consuming steps on this detail due to the amount of white over spray that has been bonded and baked into the paint for the last 6 years. The paint having never seen a detail in its life was also in poor shape - so much so I didn't need the baggie test, simply running my nitrile gloves against the surface sounded like sand paper. Here is a video showing the surface condition, and me getting very close to letting my clay hit the ground. The video is a bit shaky, but the audio is the important part.
[video=youtube_share;tvlIvciJ1_g"]Andy's Honda.m4v - YouTube[/video]
After claying and a final rinse and drying with the Master Blaster, it was time for some much needed sleep before continuing the next day.
3.- Paint correction and beta product testing.
I chose a test spot on the hood which is pretty typical to try out the beta polish I had been given to evaluate before continuing to correct the rest of the car with Menzerna SIP.
The test spot:
The test spot includes some RIDS and light scratches so I felt it was a good test point to begin with. During the testing I used the Flex 3401 VRG with a Tangerine 6.5'' Hydro-Tech pad on speed 6 with firm pressure and slow arm speed to make sure I was getting some heat in the panels to activate the beta polish.
A- Ambient Conditions
B- First impressions with the beta polish
The beta polish is very fluid, not quite water, but close. Nothing like a Menzerna Polish. I lightly primed the pad, then used an X of product and went to work. There is a lightly fruity smell. As far as using the polish it was hugely user friendly. Epically long working time, no dusting and removal was effortless with short or long nap MFs.
The beta polish I was testing specified that it was heat activated, so I checked it quickly with the thermal gun (proof that with the Flex 3401 you can get some good heat in the panels):
I was really impressed with the working qualities of the Beta Polish, so I had high hopes when checking out the results:
The paint was burnished to a very high luster and all of the light swirls were removed, however, the RIDS remained. I tired repeating the section again, and had the same results, so I broke out the Rotary with HT Cyan and Menzerna SIP (what I had planned for the rest of the car) and after wiping off the SIP (which was much more difficult than the Beta) I found that the RIDS were still there !!! I ended up having to use Power gloss, then following up with SIP to get out the level of defects that I wanted to remove.
Either the horizontal surfaces were much harder than the rest of the car, or contained many more RIDS because I had to break out the Power Gloss for the trunk and sections of the roof to get the correction that I wanted.
After seeing that the hood took Power Gloss to correct, I felt that I needed to find another section to test the Beta Polish on, and chose the left front fender - it was filled with fine scratches and swirls, but no major RIDS.
I used the same technique as before to polish out with the Beta Polish on the 3401 speed 6 with HT Tangerine.
Here is a quick look at the unpolished side (except the small spot where I polished over the tape
50/50:
000.- Products Used
Flex PE-14 Rotary
Flex 3401 VRG DA
LC Red wax pad
Menzeran SIP
Beta Nano Polish
Iron X
Tar X
OPC 3:1
Mothers Yellow Clay
MF wash mitt
1'' brush
Master Blaster
Griots Paint Prep
DP Gloss Tire Gel
Fenix Headlamp
0.- Conditions
1.- Wash & Iron X
The test spot:
50/50:
