Nice setup. I picked up a couple of those cabinets a few years ago at Home Depot for about $100. each. They have very good quality for the price and have worked out really well for organizing my car care things. I did add the hardware so I could padlock the doors closed. Keeps the borrowers hands out when I'm not around.![]()
Whats that on the right side, bottom shelf!?!:cheers::cheers::cheers:
Yep... those should definately be moved up closer to eye levely, you don't want to have to bend over to grab your most used detailing supplies.![]()
Lowes sells this rubbermaid cabinets on the cheap, they are about 1/2 size (6 feet) and can be installed quickly on walls with a couple of bolts. Perfect for smaller chemical collections, MF Towels, or carnauba collections. Best part they can be hung up a bit higher so you can still store lawnmower and other items under it.
SpaceRite Wall and Base Cabinet
umm just make your own thread........Did not know where to post or ask this question. So I came here!
Does anyone have the Tornador Cleaning Tool? If so I like to hear your feed back on this tool. Detail king sells it. The tool connects to an air line to dispense an enzyme cleaning product. A lever is used to stop the solution and air dry area.
