Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
The word holograms means a specific scratch pattern inflicted into paint using a rotary buffer
The discussion about holograms comes up all the time in the car detailing world. The word holograms means,
The pattern of swirls you see are actually scratches and the pattern you see in the paint mimic the direction a rotary buffer was moved over the surface.
Sometimes people will refer to micro-marring caused by the abrasive technology and/or the pad used on an orbital polisher as holograms. But these scratches are not holograms but micro-marring. It is true that on darker colored paint you can see a pattern in the paint that mimics the way an orbital polisher was moved over the surface but even so, this pattern and these scratches are not the same as the scratches instilled by the single rotational direction of a pad spinning against the paint when using a rotary buffer.
One reason it's important to distinguish between the two types of scratch patterns is so that everyone in our industry is on the same page when discussion paint defects. While a Ford Truck and a Chevy Truck are both trucks, they at the same time they are very different merely because they are built by very different companies.
Hologram Scratches
These are holograms instilled into the paint by a rotary buffer and a wool pad.
1969 Corvette
This Corvette has a long history as a race car but the current owner tamed it down and now just cruises it to car shows.
Problem was... the dreaded holograms...
Hologram Scratches
1969 Corvette
