Thinking about a foam cannon setup, need help
Bill1234
I am considering asking for a foam cannon for the holidays. If possible, I would go for the power washer for about 180 bucks, and then the actual reservoir for the foam I would ask for. My issue is what one do I get. I would be using a ryobi or greenworks electric washer with about 1800 psi max. Should I go for the autogeek one or the chemical guys?
That is the same as the one everyone rebrands for themselves. I am however pretty sure you shouldn't have posted that link.
Yea not sure if you should have posted that link. However, the one posted has a max PSI of 5000 which was designed for a gas pressure washer. If you look in Amazon there's an exact one that has a max of 2600 PSI for electric washer. I have both and find the 2600 max PSI works better on my Sun Joe 2030PSI. The foam cling on the paint better than the 5000 max PSI one.
