Menzerna Products:
Like polishing glass, the smoother you make the paint or clear coat, the more pronounced the reflection. The limiting factor of any polish is the size of the abrasive particle used. The smaller the abrasive, the smoother you can burnish the finish. The very fine tolerance of abrasive particle size used by Menzerna polishes that allows for a consistent breakdown and thus consistent micro marring free finish when used.
These diminishing abrasive polishes are foam pad ‘dependant’ as far as its paint correction / renovation abilities are concerned and they appear to work better when the foam pad is ‘primed’ (a very slightly distilled water dampened foam pad (do not use a quick detailer (QD) as the wax will reduce the friction heat, negatively impacting the diminishing abrasives) Apply the compound or polish to the surface and spread the polish using the foam pad with the machine off.
This coats the pad and the surface being polished with product to prevent scratching or hazing the finish, then place the foam pad flat on the surface and turn the machine on. Do no, under any circumstances, turn the polisher on with any portion of the foam pad dry as this will produce hazing (dry polishing). The use of a duel level foam pad / polish system will really heighten the paint finish shine. Remember to use the least abrasive first before ‘stepping-up’ to the next abrasive level.
Diminishing abrasives require friction heat to activate them; they will not finish up dry, but will always have a hazy film to them. Polish to a haze’- when a polish "flashes" from a liquid paste to a light semi-dry haze; its colour changes from the polish colour to almost transparent; the polish has then broken down and is ready for removal. It is important to know when a polish has broken down because if you take it too far you (dry polishing) will re-introduce surface marring conversely if you don’t work diminishing abrasives sufficiently they will cause surface marring (this is due to the size of the abrasive and its cutting ability, once an abrasive has broken down it will burnish the surface as opposed to cutting it)
These polishes were designed to work in the controlled temperature / humidity environment of a vehicle manufacturer’s paint shop finishing line, so be aware that working outside you may have issues like excess humidity, heat, cold, etc that will affect there performance especially with the Nano polish (105FF) as it uses wax as a lubricant (colder temps may cause the wax to harden) It should also be noted that these polishes use an oil in water emulsion for lubrication, if you are using a polymer after polishing it will be necessary to wipe-down the paint surface with Menzerna Top Inspection or a 1:1 solution of isopropyl alcohol (IPA) and distilled water.
Key - Cut / Gloss = 0 - 5
1. Power Gloss (POS 34A) PG will remove 1000 grit, cut 5.0 - gloss 1.5 (LC Foamed Wool, Yellow or Orange CCS foam pads)
2. Final Polish (PO85U) FP will remove 2500 grit, cut 3.0 - gloss 4.0 (White LC CCS foam pad)
Both Super Intensive Polish (SIP) and Nano Polish (106FF) were formulated for Ceramiclear paints, the micro diminishing abrasives are milled finer and much harder, and also contain a higher abrasive content, 7% were as the other polishes contain 3% abrasives. All Menzerna’s polishes can be used on any isocyanate polyurethane (conventional clear coats)
3. Super Intensive Polish (PO83Q) SIP will remove 2000 grit, cut 3.5 – gloss 3.0 (primed Orange LC CCS foam pads)
4. Nano Polish (105FF) will remove 2500 grit, for light surface marring and / or surface finishing, cut 2.5 - gloss 5.0 for LSP ready use a primed White LC CCS foam pad
5. Final Finish Polish (PO106FA) the up-rated version of P0106FF, will remove 2500 - 3000 grit, for surface finishing, cut: 2.5 – gloss 5.0 contains very finely milled micro diminishing abrasives that have a sharp edge that can cut ceramic clear coats as well as the more conventional clear coats, for LSP ready use a primed White LC CCS foam pad
Hope this helps - :cheers:
