Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
Any particular reason why I would be asking for trouble?
The fact I might sand too far is the only cause for concern?
Good question, fair question...
First read my article here and I explain in detail the topic of wetsanding paint...
Wetsanding - Fresh Paint vs Factory Paint
And here's the deal...
- Sanding removes paint
- Compounding removes paint
- Polishing removes paint
Some people, perhaps yourself are not concerned with removing 100% of the sanding marks, I tend to be held to a higher standard, so 100% is my goal and standard.
At some point, chances are really good you'll make a mistake and by this I mean you'll ever sand through the clear layer or buff through the clear layer. Now it's time to visit a body shop.
I've been there and done this and made the mistake and paid to have a hood repainted. It doesn't really matter how good you are, the odds are stacked against you. This means, thin paint and hard paint. Bad odds.
If this is a daily driver, then buff it out and remove as many defects as you can and then learn to live with the rest as chances are good you're going to get more scratches and other defects into the future and you can't continually compound or even sand each time you want to remove all the defects.
At the same time... it's your car, do as you will. My job is to give you some sound advise.
Also keep in mind all the UV protection for the basecoat and for the paint as a whole is in the clear coat. The more clear you remove, the less UV protection, the greater the risk for clear coat failure. This is especially true for someone that lives in an area with intense sun rays.
Read this article,
Beginning Clearcoat Failure
I am looking at getting more and more into panel beating/detailing/spraying etc and this car is my second car (daily). I am not super fussed about how it turns out, more wanting to learn then anything....that said I don't want to ruin it if i can avoid it
Two suggestions...
1. Get a junker panel and practice on it first. After you get some experience and feel more confident with your skills then move onto your car.
2. If you do sand on you car, limit yourself to a single panel. That way if you make a mistake it's limited to this single panel.
And do get a rotary buffer, a good wool cutting pad and a good compound. Make removing sanding marks as easy as possible on yourself.
Hope that helps...
