evo77
Member
- Mar 15, 2008
- 618
- 19
PRIMER still offers an initial layer of SiO2 for the top layer of coating to bond to vs standard polishes which do not. The difference can be felt when removing the coating on surfaces prepped side by side. I always use a panel wipe also. Even if I apply ceramic the next day. More important then really given dust that will settle on the vehicle overnight. You don't however have to wait 24hrs. Use primer, buff off and then panel wipe once completed and then coat.
So your saying PRIMER, even when wiped with a panel prep, still leaves an sio2 layer on the surface for better bonding of the coating? Or am I misunderstanding you?
Gyeon specifically says (or has said in videos) that in order to coat after PRIMER you must/should panel prep. And I guess what I'm saying is that there is no advantage for someone to use PRIMER over another polish IF in both cases you'll need to panel wipe.
