Let me first state that I'm a wax guy with verrry limited coating/sealant experience. I've only used System X which I loved, but it's no longer available (it's still beading & shining 3.5 years after application on my personal vehicle with nothing more than 2 applications of Permanon Car done in the first few months).
I don't know anything about this "system x" you speak of... but if it is still beading 3.5 years later, I am going to assume it is not a traditional wax.
Does VX1 REQUIRE any follow-up product to maintain/boost the coating? What I'm asking is...is this a set and forget coating, such as with Optimum's Opti-Coat (or Gloss-Coat)?
I'm looking for a coating for customers who will do nothing for a good 12 months other than wash their vehicle after my application of the VX1. So, does it REQUIRE something like having to use Reload over CQuartz to boost/maintain it?
No coating
requires follow up with another product, however most all of them can benefit from it.
22ple VX1 Pro contains up to 92% pure silica. This leaves a great coating of glass on your paint, however this isn't inherently slick feeling and does not bead quite as well as some of the other coatings that contain additional polymers in them. Because of this, 22ple VS1 Final Coat can be applied on top the VX1 Pro to provide the desired slickness and water beading properties that many customers associate with "good protection".
While I do not know of the exact chemical make up of Gloss Coat, it surely contains a variety of other substances which add to its slickness, therefore this product would likely be a better bet if you are looking for a "one and done" type of product.
With that being said, any coating may stop beading at some point, but that does not indicate the coating has been removed.. in these cases, topping with a product like Reload, VS1, C2V3, etc would be the best way to enhance those properties on the surface.
Is the VX1 safe (and protective) for flat or semi-gloss black plastics, and clear vinyl film? What about glass and wheels?
Safe? Sure... the best? no. 22ple has other products specifically created for use on other areas of the car such as plastics and bare metal or wheels. 22ple VM1 for metal and VR1 for plastics. Each product is a unique chemical that has been specifically created for the substrates mentioned.
Another great choice is CarPro DLUX which can be used on both plastic and metal.
After some period of months, can you apply another coat of the VX1 directly over the first if no correcting happened to be needed (other than maybe an IPA wipe)? Or do you need to polish the first coating completely off? Or is a fine, surface polishing enough to give you a fresh bonding surface for a new coating of VX1?
I have been told in the past that you can simply apply another layer on top of an existing one if you wish. I personally would always do at least a light polish and IPA wipe down before applying a coating, but that is just me.
And maybe a newb question, but after some period of time when you do decide to remove it due to swirls or etching or whatever, how can you tell when you've removed the coating...how do you know when you are through the coating and are then into the clearcoat?
You can't tell... but then again why would you need to tell? If your goal is to remove swirls, you will go through the necessary paint correction process to produce the finish you are after, and then apply the paint protection of your choice. As long as you are able to remove the surface defects, it makes no difference if the coating is completely removed or if some areas may still remain. The coating is so incredibly thin (1-2 microns) that the naked eye would never be able to tell.
I'm debating between the 22ple and Gloss-Coat or PBLDSC but need it for people who are only coming in once each spring to have their vehicles coated, and I won't see them again until the next spring. So, top-offs, boosters and the like are not in the program...
The great thing about products like 22ple VS1 and CarPro Reload is that they are so quick and easy to use, the customer can easily do it on their own. I'd encourage you to put together a maintenance kit that you either sell to customer separately, or raise the price of your service and include the kit with each service.
Coatings are not simply a bullet proof product that requires little to no maintenance. They must be properly cared for in order to realize their full benefit. If your customers are already trained in proper 3 bucket washing, they should have no problem doing a 10 minute wipe down with one of these coating toppers every month or so to really leave their vehicles looking like they were just detailed.
Both 22ple and Gloss Coat are very user friendly for you to apply. 22ple just released 2 new coatings - VX3 signature and VX Pro 2 - both of which contain a new type of silica and are said to be quite an improvement over the original VX Pro. VX3 Signature Glass Coat is also a considerable value compared to the more expensive VX Pro 2 and even gloss coat.
Hope that helps.
Let me know if you've got any other questions.
-Zach
