Thoughts on AutoGeek Foamaster?
Here are the photos.
Shampoo used was DP Xtreme foam because it is what is advertised as being best in a foam gun. From my own experiences I have found both WolfGang Auto Bathe and Adams Car Wash Shampoo to both slightly outperform the Xtreme foam in terms of foam viscosity and dwell time. The dilution used in both foamers was 0.5oz shampoo to 8oz of water (equivalent to 2oz shampoo to 32 oz of water - or filling the bottle with water and adding 2oz of shampoo).
Foam Cannon HP and Foam Master (respectively)
Foam Cannon HP:
Foam Cannon Immediately after foaming:
Foam Cannon 2.5 minutes after foaming:
I can't seem to find any other photos after 2.5 minutes of the Foam Cannon. I'm sure I took one more.
Foam Master immediately after foaming:
Foam Master after 2.5 minutes:
cat
I don't know how that DP stuff is labeled now, but when I got mine a number of years ago the amount that they told you to use in the foam gun was so extreme, I think anything would foam at that amount. I think it worked out to 6oz/gal...GC is pretty sudsy at 1oz gallon...what I'm saying is I agree with you, at least at the time I tried the Extreme, the foaminess came from them directing you to use so much rather than any special properties of the shampoo.
They intruct to use 2oz of shampoo concentrate with apporx 6-8oz of water and to shake it in the foam gun bottle.I use 4-6 oz to get the foam I want.I use that amount with any shampoo now.Wolfgang and GC are my 2 favorites.
