Tips for working in warm/hot weather or direct sunlight
First the facts...
Paint care products will always work best on a cool surface in the shade, this is true even for products that state they can be used in full sun. Even if a product can be used in full sun, working on a cool surface in the shade will always be easier and maximize the performance of the product because warm and/or hot temperatures, plus the heat from direct sun rays will always be trying to dry out your product before you can effectively work it over the surface.
Also, there's a HUGE difference between working in full sun in the morning in a fall or winter month and working in full sun when working in August, in Arizona at noon on a black car. The temperature of black paint in August, in Arizona at noon can easily exceed 180 degrees and any liquid product applied to the paint will tend to want to dry very quickly even if on the label it says, "can be used in the sun" .
A few tips...
For those times when you don't have shade and it's warm or hot outside and you don't have a cool surface to work on, here are a few tips...
Borrow some shade...
First, look around and see if you can borrow some shade, by this I mean the shade created by a large building? Maybe under a large tree?
Working under a tree can present a potential problem for debris falling out of the tree and on to your working surface but that's the trade-off for getting out of direct sun, so if you do work under a tree be sure to clean any panels immediately before working on them.
Portable Canopy...
If it's in your budget, invest in a quality EZ-Up type Canopy to create a shaded, protected work area.
Shrink your work area down to a smaller size...
Anytime a product becomes difficult to work with, one tip you can try is to shrink down the size of your work area. This means you spread the product out over a smaller area and only work this smaller area.
Be careful not to allow yourself to do what I call Buffer Creep. This is where you creep outward from your original small section and end up buffing out a larger section. Avoid Buffer Creep. Especially if your product appears to be drying up and becoming dusty.
Why a smaller area?
Because when you're working only a small are you're continually engaging the working film of product over the area more quickly as you move the polisher and by doing this there's less time for the product to dry and dust.
Clean your pads often or switch to a clean dry pad...
It's vitally important to work clean and this means cleaning your pad often and often can mean cleaning your pad after each Section Pass no matter which type of polisher you're using.
The definition of a pass
There are two definitions of the word pass as it relates to machine polishing with any type of machine.
Single Pass
A single pass is just that. It's when you move the polisher from one side of the section you're buffing to the other side of the section you're buffing. That's a single pass.
Section Pass
A section pass is when you move the polisher back and forth, or front to back with enough single overlapping passes to cover the entire section one time. That's a section pass.
YouTube Video on How To do a Section Pass
In most cases if you're removing any substantial below surface defects you're going to make 6-8 section passes to the section you’re working before you either feel comfortable you've removed the defects or you're at the end of the buffing cycle for the product you're using.
The warmer or hotter the temperatures and the worse the working conditions, then the more often you want to clean your pads.
Rotary Buffers
When cutting with a wool pad on a rotary buffer it really helps to have a pad washer, but if you don't have one you can get by with a Spur. When using foam pads you can use a pad washer or the "Cleaning your pad on the fly" technique" using a clean, terry cloth towel.
How to clean your foam pad on the fly
DA Polishers - Porter Cable - Meguiar's - Griot's
When cutting with a DA Polisher you can get by with "Cleaning your pad on the fly"
using a terry cloth towel, but a pad washer will clean a foam cutting pad better. Of course you can always switch to a new pad or a clean dry, used pad. The "Cleaning the pad on the fly technique" does not work with the Flex 3401 or the Cyclo Polisher. For these two types of polishers you'll need to use a pad washer, wash your pads by hand, or substitute clean new pads, or clean, dry used pads.
Keep in mind that anytime you us ANY product that abrades the paint, you will have two substances building up on the face of your pad,
  1. Spent residue
  2. Removed paint
Both of these need to be removed as they build up before adding new product and continuing with the buffing process.
Back when cars were painted with single stage paints, you could easily see the removed paint build up on the face of the pad because it was pigmented or colored. This would be a strong visual indicator to help remind you to clean your pads often.
With modern clear coats, you're still removing paint when you're abrading or doing correction work but because the clear layer is clear, it just doesn't show up as dramatically as single stage paint. The important point is to understand that clear paint is building up on the face of your pad and to clean our pad often.
You also want to wipe off any residue from the area worked before adding fresh product if you're going to work the area again.
Use an "ample" amount of product
When I say use an ample amount of product this means don’t use too much product and don’t use to little product.
From The Free Dictionary.com
am·ple
adjective
1. Of large or great size, amount, extent, or capacity: an ample living room.
2.
a. Large in degree, kind, or quantity: an ample reward.
b. More than enough: ample evidence.
3. Fully sufficient to meet a need or purpose: had ample food for the party.
Out of the above definitions, I'm using the 3rd definition.
Using too much product
If you use too much you can hyper-lubricate the surface and this will make it more difficult for the abrasives to abrade the surface as they’ll tend to want to glide or slip over the surface instead of bite into the surface.
Using too little product
If you use too little product there won’t be enough lubrication to enable the buffing pad to rotate and thus engage the abrasives against the surface so they can bite into and remove small particles of paint.
You want an AMPLE amount of product when first starting out because you pad is dry and some of the product is going to seep into the pad leaving less on the surface to LUBRICATE and ABRADE the paint.
Another option is to use a Pad Conditioner to lubricate and condition the surface of a dry pad, this will improve the buffing cycle and provide protection to the paint surface to help prevent micro-marring.
XMT Polishing Pad Conditioner
Cut down on the amount of product AFTER pad is broken-in...
After your pad is broken in with product, clean your pad after each section pass and when you apply fresh product you can cut down on the amount of product you actually apply to the face of your pad.
The key it to have enough product on the surface as you're working a section to have a film of product that you can see on the surface behind the polisher as you move the polisher in a direction.
Start before the sun comes up...
Do your machine compounding and polishing early in the morning when it's the coolest. Start setting up while it's still early in the morning while it's cool, then as soon as there's enough light to safely work, begin working the horizontal panels first. The reason for this is these will tend to get the hottest later in the day as the sun is over head making any correction or polishing work more difficult.
When it comes to the vertical panels, you can usually move the car in such a way that the side you're working on is shaded to some degree by placing the sun on the opposite side, thus the surface temperature of the panel will be cooler.
Use smaller, thinner pads
The 5.5" pads are thinner than the 6.5" pads and should rotate easily with a PC 7424XP, Griot's Garage and Meguiar's DA Polishers under on the 5.0 to 6.0 Speed setting. Together with working a smaller size section and ample product this will make working on a warm or hot surface easier.
Why to only work small sections at at time
The larger the area you work the more the product is going to dry up on you because while you're working one portion of the area, the portions not being worked will tend to start drying via evaporation. By shrinking your work area down, shrinking your pad size down and using ample product you'll better be able to maintain a wet buffing cycle over a smaller area.
Note: The larger the area you work the less abrading action each square inch of paint will get in relation to the time spent working the total area.
Exception to the rule...
While most instructions state to work a 2' x 2' area, when removing swirls in a warm or hot environment, it's usually more effective to work a smaller area.
I tend to stick around the 20" squarish area and even smaller if the paint is harder, the swirls are deeper and it's extremely hot and windy as the heat and the wind together will both act to force your product to dry more quickly.
Hope this helps....
Never did like when a product claims how great it works in the sun
.......... It ends up working ten times better in the shade.
I see another great invention in the future. The "Clean on the Fly MITT"! Who wants to take that bull by the horns! LOL I am unfortunate not to have a garage at my house, however I have plenty of large oak trees that love it when I park underneith them so they can spill their lovely sap onto my paint. I have been looking into the ez-up canopy's for awhile now. If anyone see's them on sale anywhere, online or stores, let me know. With my truck I don't think it's going to matter if it's a 10x10 or 10x20, she's a big truck and I'll have to move the canopy anyway.
Even with compound and polishers that work fine in the hot sun, make sure you don't get overheated.
Shade works best for everything and everyone involved.
Mike, what size Canopy is needed for detailing outside?
Nice piece of info, Mike. I have been dealing with this crazy humidity here in FL. Nothing works right. The sun is horrible when you have to detail and have to work in it, but a 10x10 gazebo really comes in handy unless its windy.
Excellent advice, Mike, but where's the section on avoiding heat stroke? :laughing:
I don't need clay lube in this muggy weather, the sweat dripping off of me is plenty sufficient! :buffing:
what i do is wait for the sun to go down. or park next to my garage its nice and shady there..
For most mobile detailers the limitations are determined by your work vehicle, that is how much canopy can you carry. And next is how much canopy can you put up by yourself.
I used a 10x10 like the one here with the extra 3 walls that you can either use or leave off...
After doing one end of a car or truck you can either pull it out, turn it around and put the other end in or leave the back wall off and drive forward to shade the next panels.
I used 5-gallon buckets with water in them, (1-gallon = 8 pounds so a 5-gallon bucket with water = 40 pounds), hooked to the horizontal support with Bungee Cord, by doing this if any wind comes along it will lift a little and then settle back down.
See the post above and this one...
Respect
Good point, my normal habit is to take an ice chest with bottled water and a few Monster's or Rock Stars... it's important to stay hydrated...
:xyxthumbs:
That's one option, by the end of the day the earth where you live has been heated by the sun all day, the air will be hot and it will be warm or hot outside.
First thing in the morning the geographical land where you live and the air temperatures will have cooled down as much as is possible in the dark of the night and the morning temperatures will usually be cooler than the evening temperatures...
It's all good if it works for you...
:dblthumb2:
All very good and notable suggestions. always be very considerate of the particular climate you are working in. sometimes I will have to turn a car around to face away from the sun and take a water drenched MG and drag it across the surface a few time to quick cool it back down before working on it.
more important than what you are working on, everyone need to stay cognizant of their hydration level and symptoms of heat stress,cramp,stroke. which are exasperated by lack of circulating air and the accumulation of chemical fumes ( Read the MSDS)
Good info Mike! I work in the sun when working on the cars and I have a way of putting up an 11' x 16' tarp instead of a canopy but thats because I work in the same area everytime. Because of possible contamination from the wind and the elements, after prepping the paint and before I get into polishing, I wipe down the panel with a quick detailer to make sure nothing has been blown and landed on the paint.
more important than what you are working on, everyone need to stay cognizant of their hydration level and symptoms of heat stress,cramp, stroke. which are exasperated by lack of circulating air and the accumulation of chemical fumes ( Read the MSDS)
Good point... keep plenty of cold bottled water on hand and take water breaks often when working in warm and hot conditions.
Was showing that tip this last weekend at out Detailing Boot Camp Class, that is wiping the paint down after the compounding step to make sure all fragments from the compounding process are removed before staring the polishing step.
:xyxthumbs:
HMMMM.. Please help with tips and tricks for working with -8 degrees.... Arrrgghh... Mike, please have a contest where the lucky winner (from the north) gets a trip to Florida for one of your detailing classes!
I heard someone mention a contest for a trip to Autogeek to attend one of my classes, not sure what happened to the idea?
Here is my take, since I live in South Carolina, we get some hot summers where we have lots of humid days where even walking out causes you to sweat, I am sure Mike can relate being in Florida.
Most of my post keep going back to when I had my mobile business, so here are my tips. *This is for the person or persons who have a totally contained unit.
1. Buy a good canopy. I have an EZ-up Contractor grade that is big enough to park a Hummer under. It has saved me more times than not when it is really nasty hot outside. (One caveat here is that I had helpers)
2. Hydration: We always and I mean always had a full size cooler with hydration drinks, water and snacks. I cannot stress enough how much electrolytes you will loose on summer days.
3. Limit your exposure. Where lighter fabrics with full sleeves, wide brim hats help as well.
4. Working product. This is where I have to take a side and say that we rarely did full level correction on anything without the use of either the clients shop or another shop. I would do a wash and wax on these days and that is about it. My money was made in washes and convenience service, not full correction detailing.
HUMP
By the way, if anyone is living close enough to me that they would want to come and check out the canopy, I would sell it. Message me and we could set up something.
1. Buy a good canopy. I have an EZ-up Contractor grade that is big enough to park a Hummer under. It has saved me more times than not when it is really nasty hot outside. (One caveat here is that I had helpers).
Have a good way to anchor it down to in case it's windy outside. I've used 5-gallon buckets with water in them, at 8 pounds a gallon a 5-gallon bucket weighs 40 pounds.
Don't tie them to the canopy with rope as this will just cause the buckets to spill, instead use a bungee cord because it will stretch. If you can park your rig next to the canopy and somehow use the weight of your rig to anchor the canopy down. The big picture is you don't want your canopy blowing around possibly damaging a vehicle.
Two great tips...
Another great tip, focus on doing simple work as in Keep it Simple Simon....
Thanks for your contributions to this article HUMP...
:dblthumb2:
Great write up Mike, Thanks. I have been putting what you taught and what I have learned here to good use, but this heat in Central Florida is killing me. Product dries way to fast and act's differently. I look forward to the day I can build the garage and wash bay.
The very few times i have been forced to work in the direct sun of FL, i do 2 things: cover the next section i am moving to with a WW MF towel and top that with a "cooling pad". I have two cooling pads that are designed to be rinsed in cold water, wrung out and draped around your neck. Does wonders to keep me cooler in the brutal hot sun (with frequent rinses!). I will use one of them to lay on top of the MF towel to keep the next panel section cool.
The second thing is like Mike said...i work smaller sections.
This is mainly an issue with top sections as i can move the vehicle to get the sides out of the direct sun.
Great post Mike. Hopefully this will help out with many of the questions people have been asking on this topic.
Sent from my SAMSUNG-SM-G900A using AG Online
I have a question:
Generally, while polishing, I may stop immediately if I touch surface and feel it's becoming 'damn hot'. A little heat may be expected, but I never let it raise to the level of a 'full sun over a black car' feeling, if you know what I mean.
My question is about this: I stop polishing if heat is building up fast, how to deal when polishing a surface that is, from the start, 'damn hot'?
Wouldn't this increase (a lot) the potential burn of paint?
I mean, I'd be really scared running a compound over a 'damn hot' paint, even if product states it can be used under full sun.
On my reasoning, the product drying fast would be not my main concern..., since all those tips seems to deal with this issue in a efficient manner.
Thanks in advance for help,
Kind Regards.
