Tire shine. Which one?
You'll need an aerosol with all the tire lugs. It would take forever to put Megs Endurance on 10 giant off-road tires. The GG Tire Coating spray works very well and dries to the touch.
Optimum Opti-Bond Tire gel and a HVLP gun maybe be what you need. Product is pretty cheap, mix at your desired dilution and with the HVLP gun you've turned it into an aerosol.
i have a bottle of opti bond i will most likley look into a HVLP gun and hopefully that will do and last a great while
You could just buy a case of more shine less time from here and spray them down and not care about wiping off over spray. It's not a concours entry.
I purchased a Wagner HVLP gun way back when Opti-Bond first came out. The tool has held up fine. I will spray soapy water through it every once in while to clean it out. This set-up with Opti-Bond is what I go to for big truck tires.
10 big ass tires i would ask couple of my friends to help. It has to be clean and I would use optimum opti tire gel. 2nd coat of the tire gel about 30 mins later. Gotta polish them wheels too! Check out zephyr polish in IG and YouTube
Polished & dressed.
For tires I use carpro perl. Best shine, dry to the touch, no buff no sling.
