Is there a code or just walk in and ask for the discount
Sent from my SPH-M930 using Tapatalk 2
Glad it worked for you my friend!Thanks Cardaddy
I use hyper dressing on the engine and wheel wells. I don't like it on tires just because of the over spray. I hate having to wipe off the wheels and. Do you let it sit for a bit then wipe the tire because I have used it before and it can dry runny
I used PERL as well but when I ran out I thought I'd try the DG 253 and WOW same look's as PERL but lasts twice as long.:xyxthumbs:i also have used HD on engines and wells. don't care for it on tires as well. i find it's short lived compared to other water based dressings on tires and diluting at a higher ratio IME attracts dust/dirt. if i was doing this as a profession (which i don't) and see dozens of cars a month then using this is cost effective and a no brainer. after using PERL, i really don't use HD anymore...
do you like it? I've been using it for awhile and not to happy with it. Think I'm gonna try something different.I use PoorBoys Bold and Bright. Last a while on the tire.
Ed
Ed
