UncleDavy
- Aug 22, 2017
- 1,614
- 26
Here is a helpful hint when working on tires. Use a piece of 1 x 4 or similar item to elevate the tire. This allows you to work on the entire surface of the tire whether it is cleaning or coating. I had some Trex decking material leftover from the deck project and I cut four perfect length pieces.
For cleaning, the most economical tire cleaner is LA Totally Awesome cut 1:1 with water. Two scrubbings and the tire is clean.
