marsomthing
- Nov 16, 2011
- 27
I was doing a correction for a friend who got keyed recently and everything but the deep stuff came out I was using griots da...
I started with a white ccs pad with mg ultimate compound then after very little correction I went to a 3 inch orange ccs pad.(light cutter)
First pass I saw a good bit of correction, moving in the right direction, moved rpms up to 6 even better. Since working with a heavier pad I only did 4 passes per application, but I did it like 6 or 7 times maybe more, BUT each with better results. When I got it to where I thought was best (not perfect but hairline) I stopped and saw buffer marks. Broke the 6.5 white pad out with some ultimate compound went over twice to smooth it out with good results. But I felt like I was chasing pad marks every time I wiped it would move a little further, so I went a pad lighter until I was satisfied. Was I chasing because I cut so much with the orange pad
My question is....can you use a pad to much in the same spot? ie my using the small orange pad a good bit in the same spot?
