Northwoods
Member
- Jun 13, 2016
- 62
- 2
I recently used a DA polisher for the first time and polished my Tundra. I used the GG G9 with 5" backing plate, 5.5" green LC flat foam pads, and BlackFire One Step.
It took a little getting use to but after a while I got the hang of it. I used 5 pads to do the whole truck. I would condition a new pad by Mike's recommended condition method by apply a couple rings of product to the face of the pad and then smeared it around covering the entire face. I would then use 3 dime/nickle sized drops per panel. I would start off on speed setting 2 to cover the panel with the product and then increase the speed for my section passes. Problem is when I when to speed 5 or 6 I got some bad splattering where product would splatter all over. It would happen when I was on flat horizontal or vertical panel surfaces and when I was working over panel edges or smaller/narrower panel sections like pillars or bumper. Also down pressure on the pad didn't seem to make a difference. Splatter also seemed to be worse when I put on a new pad compared to once I had one nicely lubricated with product.
After this happened maybe 4 times and I took the time to clean all the splatter up each time (royal pain in the a$$), I used speed setting 4 instead of 5 or 6 and it worked MUCH better and I still made sure the pad was rotating. I hardly got any more splatter so I just finished the truck using speed 4 and about 4 to 5 section passes per panel. The pad would rotate better on speed 4 when it was well lubricated with product.
Again I'm brand new to this, so things like down pressure on the pad, amount of product and how far I can make one pad loading go are all new to me. I just have never seen the splatter I was getting on speed 5 and 6 in any of the how to videos on here and was wondering if I was doing something wrong? I did not mask many areas for sake of time but when it splattered on speed 5 or 6 I'm not sure masking would of helped much, product went all over.
The truck turned out well for my first DA polish job, but I'm sure it's far from perfect for many of your standards and I can still see some deeper scratches and swirls but it did certainly correct some. The good news is, it's the best the truck has looked in years and the BF One Step is easy to clean off areas where you don't want it... if it wasn't I'd still be cleaning up splatter.
Any suggestions on my process and what I might do different or if the splatter I was experiencing is common? Is speed 5 or 6 on the G9 higher than on older models? I'm sure I would of polished paint better on speed 5 or 6 but the splatter was too much. Thanks.
