My question is, should the blue step (step 1) remove all spiderwebbing or do they decrease as I move from course to fine?
Great question and a lot of factors involved into how EFFECTIVE you or anyone is at 100% defect removal. Here's a few,
1: Experience - HUGE factor.
2: Depth of defects you're trying to remove.
3: Hardness or softness of paint.
4: Product.
5: Pad.
6: Technique - I've met people that run their tools at low speed, only make a few section passes with light pressure and don't understand why they didn't remove all the swirls and scratches.
As of this morning, Monday, June 15th 2020 I have over 641 how-to articles on the AG forum,
Here's two that might help you,
While I original wrote this before your tool was invented, in fact, about the only tool readily available besides the rotary buffer, the Cyclo and the TOB was the Porter Cable dual action polisher, the PROBLEMS I list and the SOLUTIONS I share all apply except downward pressure.
With long stroke tools you only use a little more pressure than the weight of the tool,
A: So you don't stall out the pad rotation.
B: Because the LONG STROKE that moves the abrasives over the paint is more effective at removing paint than a short stroke action and thus you don't need as much downward pressure.
Me? I use gear-driven orbital and plow through cars.
DA Polisher Trouble Shooting Guide
What it means to remove a scratch out of anything...
