The Enforcer
- Jan 29, 2014
- 86
I coated a brand new set of tires with tuf shine this week. I did not use their cleaner, I used my own. All the new tire "wax" was removed and the tires appeared to be 100% clean. I applied 4 coats to reach the desired level of gloss and allowed each coat to dry to the touch before adding the next (ten min in between maybe). When they were done, it looked unbelievable! However, if you put any pressure on the sidewall...the coating CRACKED. IT looks much like shattered glass. The tires were not touched for two days so cure time is not the issue. What happened?
