Uggghhh @#$#!^% tree sap
runrun411
Hi geeks, it's been awhile since I last posted but I'm always reading you guys post. Over my driveway is a couple of pine tree that spit that damn sap on my cars. I usually use Purell to get it off. When there's so much of it this can take awhile. What product do you think will work fast and easy?
Purell is mostly (denatured)ethyl alcohol, with some
IPA mixed in the solution.
There are products labeled as "Tree Sap Remover"
(BAF/Pro's C-46 comes to mind)...that also basically
contain similar ingredients, especially IPA.
Then there's:
"Like Dissolves Like"...Turpentine.
Just did a detail this past weekend where the ppl have a huge pine tree they park under. I use alchohol but I ran out because there was so much sap every where. In a pinch for time..call me
crazy but I carefully used break cleaner sprayed onto a micro fiber and spot cleaned the rest off. Worked like a charm:dblthumb2:
I use Tarminator, spray on a rag then wipe. Works well for me.
I tried the 91% alcohol. Wow what a difference. Cleaned up really fast.
