Does Ultima Tire & Trim Guard dry to the touch?
Reason I asked is that I applied it to the rubber door seals and hard black trim but it never did dry to the touch. Even after buffing the trim.
Depending on the temp and humidity it will dry in a day. I use a foam brush and 8 hrs. later use a old mf towel wrapped around my finger with a drop of UTTG and smooth it out. I just re-did my trim after 5 months with no garage.Does Ultima Tire & Trim Guard dry to the touch?
My theory is: Because seals are very small and thin it is easy to apply it too thick since you can't spread it around. If there are any larger areas of trim on the vehicle maybe do one of those first with one spritz and then do the seals with whats left on the applicator.
I think that mainly its because the seals main purpose is to keep things out, so they are very non-porous and smoothed over. It does not allow any of the product to enter it, so unless you're very careful applying the product (which is hard because like you say--its very small and thin) it will pool up on the surface and take a long time to cure.
