How does Meguairs Ultimate Compound compare to CarPro Fixer in terms of cut with a DA?
Anyone have experience with Menzerna FG400 and Wolfgang Uber Compound in comparison to Meguairs Ultimate Compound in terms of cutting ability?
I guess the underlying questions to both are:
1] What are you trying to achieve with your compound?
2] What state are the paint's you'll be working on?
Its nearly impossible to give blanket answers about products without knowing the intended uses. [context]
Should be about the same. However, I think there's more technique involved with fixer. UC is very fool proof.How does Meguairs Ultimate Compound compare to CarPro Fixer in terms of cut with a DA?
Just get a bottle of UC and M105 and if you need more cut add a drop or two of 105 to the pad along with UC. Or you can mix a couple ounces of each in another bottle and adjust as needed. I actually mixed some D300, UC, and M105, and the cut and buffing cycle were amazing.![]()
