Ultimate Compund much more user friendly than M105
WRAPT C5Z06
It's next in line to M105 interms of aggressiveness, so it's gott be close. I tried both today via Flex 3401. M105 had a very short buffing cycle and was a *b!tch* to remove!!! Tried Ultimate Compound, it had a much longer buffing cycle and was a lot easier to remove. Maybe this is because I'm a beginner, but UC > M105. :buffing:
UC has more lube, but less cut than 105. If you can remove defects with UC it would be easier. You should still finish down with 205.
:iagree:I have to agree with you. I have done two vehicles with it so far and it was very easy to work with!!
Does UC have more cut than Menz SIP?
I polished my sisters black honda pilot. Used UC w/orange CCS. Finished with 205 w/white CCS. :xyxthumbs: Also, tried a cyan hydro tech pad. IMO, the orange CCS has more cut.
They are about the same... UC might have a hair more cut than SIP. You shoud try one last step with menz 85rd and a black pad for jeweling.
I used speed 6 with the flex 3401, orange pad, and UC. When I used 205 with a white pad, I used speed 6 as well. Should I use a slower speed with the 205? I've heard a lot about 85rd, I think I'm gonna try it.
Ultimate Compound has a lot of play time, really is a great product for use with the D.A or even by hand.
When using DA's or 3401 it's max speed. I can only handle speed 5 on the Griot.
