Ultimate Wash and Wax Anywhere
Honestly, you need to buy a gallon of Wolfgang Uber RW and make gallons of WW with it. Initial investment is high but as good as Megs UWW is and IT IS, that can get expensive. To keep things safer and slicker I use 2.5 ounces with a gallon of distilled water to make a gallon of WGU WW.
If you use this product as just a WW it will save you money, lots of money as well as time because your not going to the local store to buy Megs UWW all the time.
Btw you could and should do RW as well and of coarse WGU excells here as well. If the car has 7 days worth of dust and dirt going the RW and pre-treating is a MUST. Get some plush, edgeless mf towels and you'll be set with either method.
Waterless + a good pre soak + a pressure sprayer, a pump kind works good enough would work wonders. Auto Finesse Citrus Power and a good waterless or rinseless would be awesome. That AF product melts caked on stuff off paint It's LSP safe but from the times I've used it, removed everything it came in contact with. A pretty amazing product if you ask me.
Now there are probably cheaper products you can use for this, I'd be curious to hear form someone who's used AF Citrus Power and can compare it to others. It's the only thing I've used.
