aim4squirrels
Active member
- Nov 6, 2013
- 1,078
Yes Bob I know that but to say that a DA polisher can not break break down DAT products is incorrect. Before the SMAT was introduced all we had to work with was DAT products.
M1 is rotary only and is being used in the wrong way. More suitable product that work at better would be M205 or even M105
I think you misunderstood my post. His machine cannot break down THAT DAT product. It was not a base generalization that a DA machine cannot break down any DAT product. Whether is because there are too many oils, rocks are too big and strong, it has a magical enchantment against DA Polishers, whatever, it isn't working with that particular product.
Which is why it says on the label rotary only. The use of DAT in my previous post was to emphasize the rocks were bigger and that's why he's getting the bad results.
Now, if you can buff that stuff down and make it look good on a DA, then good on you, that's some skill. But that's a lot of work to prove a ticky-tack point, and the OPs time would probably be better spent with a better suited product to get the results he's looking for.
