I am in the process of doing the first detail on my wife's 2019 Mazda 3. The paint has a lot of swirl marks in it for a 9 month old car (thanks to the dealer) but I've seen and corrected much worse in the past. However, I have run into quite a bit of difficulty trying to correct this particular finish.
The paint was cleaned with iron remover and clayed prior to starting correction. I had to do several test spots on the hood before I found a combo that had any effect at all on the swirls. I typically use Adam's products and have had very good results with them up to now on cars with much worse damage. I tried their compound with several different pads but even the most aggressive pad I have (Lake Country Hybrid Force Grey Pad) gave little to no reduction in the swirls. I ended up trying an older bottle (3-4 years old) of Meguiar's Ultimate Compound I had left over with the Grey Lake Country pad on a Flex XC 3401 VRG and finally saw some improvement. I needed 6 passes per section with the speed between 4 and 5 to remove most of the swirls in the test spot. I did the hood and front fenders and got most of the swirls out but I did need to do several sections twice.
I started out today on another panel with the same technique but it now has almost no effect on the swirls. I have tried smaller sections, slower hand speeds, more pressure on the buffer, and higher buffer speed, but nothing seems to work. The weather is hot and humid (Central Florida), but it was the same yesterday when I did the hood and fenders.
I'm pretty much out of ideas as to how to proceed. Right now, I can think of 3 potential causes for my issues:
1) Expired product (my bottle of Ultimate Compound is at least 4 years old). I'm planning on buying a fresh bottle tomorrow and see if that helps.
2) The car has a paint sealant or coating that was not taken off by the iron remover. I have not applied anything previously, and to my knowledge the dealer did not either. The only possibility I can think of is a paint protectant from an automatic car wash that got applied without my knowledge.
3) This car was built with the hardest paint on the planet.
Any comments or suggestions would be greatly appreciated. I really don't know what to try next.
Thanks in advance!
Todd
Thanks in advance!
Todd
