Understanding headlamp repair
Barry Theal
Understanding Modern Headlights on Today’s Cars.
By Barry Theal of Presidential Details and Lancaster Headlight Repair, Often the littlest things on a car can make a huge difference in both safety and appearance for you and your fine automobile. Today’s modern headlights can quickly become hazed and yellow. This is a result of oxidation to the UV coating on the lens. In some cases the lens can be polished without disturbing the coating to a like new OEM finish. Others will have to have a more complicated approach to resurface and restore. In this article I will explain why this happens and what you can do to properly fix it.
Headlights use to be made of glass prior to 1980. Eventually manufacturers in the automobile industry were changing designs and needed something they could easily form to a mold. Thus they began to look into newer sleeker materials that were lighter and could contour to a more aerodynamic shape. They ended up using a material called polycarbonate or the proper name Lexan. Polycarbonate is used in many products today; ranging from sunglasses, safety glass, eye glasses, to basketball backboards. It’s a very tough durable material, virtually impact resistant as well. The weight is much lighter then glass which plays a major role in today’s modern sports cars.
While polycarbonate has many great features it also has several downsides that could cause a concern for drivers today. Polycarbonate alone is not able to hold up to environmental issues like the sun. Over time it will become very dull and faded. Next, manufacturers decided to put an Ultra Violet coating over the lens to prevent this from happening. While this was a great fix to keeping the polycarbonate from fading and dull out instantly while underneath the sun’s rays, it also has issues.
The easiest way for me to explain this coating is like clear coat on a car. Clear coats purpose was to add protection to the paint. Remember how older cars often oxidized. We have all seen those pink cars that were once red. This is the same thing that happens to the coating. It oxidizes and fades to a dull look. This robs from a vehicles’ overall finish, and also brings a very big safety concern. Over time this dull appearance will block light transfer and the headlight will not be able to produce the amazing brightness it once had.
Over the years many companies have claimed that they can restore headlights to new condition by sanding and polishing them out. This is often referred to as a “scuff and buff” fix. From first glance, the result can be amazing. However, this is not the best approach. During this process the factory installed UV coating has been removed. Once this coating is removed there is no wax or sealant that will be able to hold long lasting results once the protection has worn down. The polycarbonate lens will actually fade 3 times as fast. This usually happens with in 3-5 months of the scuff and buff fix. Over time you will constantly have to have your headlamps sanded and polish. Most places can charge in the range of $80 – 100 dollars for this. This is a complete waste of time and money for the consumer. Some may say 80 bucks isn’t all that bad twice a year. The problem isn’t within the cost itself. The concern is that polycarbonate is only so thick, repeated sanding and polishing will ruin the lens permanently. So what’s a new lens cost? Recently a customer shipped me some lenses and he said that a new headlamp assembly was $1200.00 for one lens!
In order to restore the lens back to its OEM standards a new UV coating must be re-applied. There are several companies who can provide the coating. I will leave out all company names so no promotional advertisements are provided. During the part of this article I would like to show how to properly apply the coating and the steps involved.
In the below picture you can see how these lights had seen better days. Take notice this is an extreme case. These lights hardly had any transparency at all. It was difficult to see the bulb on the inside. Here is how they looked prior to repair.
First thing you want to do is to clean the entire lens. For this I used all purpose cleaner to remove any dirt and debris from the lens and the housing.
Next, It was important to mask everywhere. I covered all the rubber edge moldings. This ensure no coating overspray and also prevents the housing from being nipped with the sander.
The following step I used a sanding lubricant that is designed for polycarbonate cleansing. It foams nicely and allows for a very smooth surface.
Once sprayed I began to sand the entire area first with 400 grit, then 600, then 800 and worked my way up the ladder to 1500 grit as a final sanding. Keep in mind just like paint some headlamps have a harder UV factory coating. Porsche has a very severe hard shell. It takes a lot to get the entire coating off. In most cases I have found that 800 grit is a great start.
Once both lenses were finished sanded to 1500 grit, everything got masked and taped prior to applying, the new coating.
Next we mixed our new UV coating catalyst into our spray gun and began to apply the coating.
All finished up after the curing process.
Finally, I got them all put back together and placed them on the table to be sent back to the owner.
Using this unique new system, I am now able to provide a long lasting result that I can provide with a 3 year warranty for protection.
In conclusion, from my finding this is the only proper way to restore a head lamp housing is to reapply the coating. I tried to make this article informative for both the detailer and the consumer. If you have any questions please contact me personally.
Barry E. Theal
Great article Barry. I was hoping you would post a write up after the discussion on Friday so that people could see the proper way of doing this.
Thanks,
Richard
Very immpressive Barry. Thanks for posting your findings here @ Autogeekonline :props:
Thanks,
Richard
No doubt ^
Whilst I've only had the 1 paying job that was a friends car and he stiffed me out of $10, it is nice to have a thread I can turn to should the need arise.
Thanks again Barry
Excellent well written and informative article Barry! Thank you
Excellent thread Barry. Now people can finally see a true headlight restoration and not just sanding, buffing, and applying furniture clear on it. I've been preaching and doing it this way for a while now only with sanding up to 800gt and using a 1k clear vs a 2k.
People dont understand that you need a rough sanded surface, not a smooth polished one, for the clearcoat to adhere properly.
Excellent write-up, Barry!
As you say you are able to provide a 3 year protection warranty, is this something backed by the manufacturer of the coating product you are using? Or are you just offering it in good faith based on the claims of the product?
Anyone not doing headlight reconditioning this way is doing it wrong!!! The only alternative to finishing this way would be to polish to completition and then coat the lens with something like Opti-Coat. The days of buffing and waxing lights should be over to anyone wishing to do it right. Great info Barry!
great writeup but im confused a bit
- after the final sanding you sprayed the UV protecant on it, what did you do to make it clear again? Was the 1500 sanding job enough to do that?
I had the same question as above...
also, what do u do if you dont have an airbrush?
Any time you're spraying a paint or sealer like this the surface you're spraying onto needs a bit of "tooth" to provide mechanical adhesion of the coating to the substrate.
Leaving 1500 grit scratches on the lens surface provides adequate tooth in this case and when the sealer/paint is applied it fills in these scratches, automatically restoring clarity as the new film-build self levels and cures on the lens surface.
:dblthumb2:
No, the UV coating is clear coat paint that cures in only a few minutes with UV light. When you spray clearcoat on the sanded lenses the clear fills in those light scratches and makes they clear and glossy making them look brand new. It needs to be sanded because the paint need something to bite onto. Otherwise it could just peel off in coming months.
You can use 1k clear in an aerosol can like I do, or you can use 2k clear which is more expensive and cannot be saved and must be used within 24hrs. 2k clears are pretty much the same type of clearcoat on your car that uses a 2 part catalyzing system.
wonderful info! another question
- what the heck is 1k and 2k? where can I get it? :)
1K vs. 2K refers to non-catalyzed vs. catalyzed paint -- 1K, being non-catalyzed, takes longer to cure and uses different solvents than a 2K paint.
Here's a bit of additional information about the differences:
1K Coating vs 2K Coatings
You can get 1K clear at most auto parts stores, as well as both 1K and 2K clears from any local PBE distributor. One of my favorite clears is sold under the brand "SprayMAX." I pick it up at Finishmaster locally.
^^ Excellent post.
I like using SEM 1k HS clear as it is a fast drying clear with high film build ,like 2k system, requiring less coats. I get it at my local bodyshop supplier.
alright! found it on amazon for $14 for the 1k. I learned a lot, thanks for answering gents.
I suspect there will be a surge in Opti-Coat 2.0 sales. I just hope that people realize it is a permanent coating and that all sand scratches/marks should be removed prior to coating, otherwise their restored lights will have locked in defects. Opti-Coat will not fill these like clear coat does - according to Optimum.
^Damn right!!
I'll be getting some opti-coat for the headlights for my dad's car!
I had sanded and restored them but now I have to seal them like every week or so to protect them from hazing again.
Btw really great article Barry. :xyxthumbs:
Since I don't have any spray equipment, I'd have to do with opti-coat or similar coatings.
