Upcoming Sea Ray 340 Correction
Shtexas
So I have the Sea Ray pulled out of the water and in dry dock to inspect. It's going to be pressure washed and the bottom is being repainted. The propellers and rudders are getting refinished as well. I'll start the correction process in a little over a week.
It's a 2001 Sea Ray 340 Sundancer. The interior is very good condition. The exterior as you can see in the pictures is need of work.
The canvas is currently at the upholstery shop having new zippers put on. I'll be cleaning and treating it as well.
I'll start off by wet sanding the the gunwales and other smooth areas on the deck, as well as the arch. All of these areas were exposed heavily to sunlight and rain for the past few years.
After wet sanding I'll switch to the rotary and wool pad with a heavy compound. I'm thinking of trying the Marine 31 Heavy compound this time. Afterwards I'll follow up with the Marine 31 Gel Coat Gloss and Color Restore. My LSP will most likely be Collinite. It has the best durability I've seen on boats.
I'm going to clean all the non skid with starbrite. It removes all the stains and leaves a nice white surface.
The vinyl, carpets, helm, and other areas in the boat will be cleaned with diluted purple power. The vinyl and plastics will be protected with 303 afterwards.
Here's some before pictures. The red line in some of the pictures is a divider I put. Underneath the line is just getting rotary work, above the line is being wetsanded. It's hard to see in the pictures, but the hull still has a slight amount of shine to it.
You can see a little of the shine on the hull in the picture above ^^ not much sunlight, it was early and overcast.
Thanks, it's my second Sea Ray. I like them a lot. I have my work cut out for me though.
Sea Rays & Cigarettes are my choices ! lol .
It will take days to detail I guess !
Yeah I'm thinking about 4 days on the sanding and rotary work. Then another 2 days on all of the vinyl, glass, canvas, metal, and engine compartment.
Remember when my late father had a Trojan yacht , ( it was like over 20 years ago ) it took what seemed like weeks for us ( my & my brother ) to detail back then .
What was your first Sea Ray buddy !
It was a 1991 Sea Ray 400 Express Cruiser. It had the optional 502's. Nice boat, it loved to suck down gas though.
I have experience detailing boat exteriors and interiors, but I was wondering if anyone had any experience or insight in detailing engine compartments in boats this size. I was thinking of using diluted APC and a brush to clean everything, and letting it drain out of the bottom from a drain I opened. I would make sure not to get the apc on any electrical equipment.
So I've been pretty behind with the boat and haven't been able to start yet.
I planned on doing some routine maintenance before starting and as it is with boats, the routine maintenance turned into some major repair work.
The generator won't start so I went in to see what was wrong with it. It only has 9 hours on it right now. 9 hours on a 2001. The break in time is 10 hours so it's not even broken in. The carb ended up being pretty fouled so I went ahead and rebuilt it.
The exhaust manifolds on each engine, the exhaust riser, and the raw water intake pumps also need to be replaced which I'm in the process of right now. I should be finished next week and starting on the outside detail.
Well It's been awhile since I've given an update.
Seems like it was one thing after another that needed to be fixed or replaced. Instead of being out on the water this summer I've sunk about 15k into it to get it ready.
-After finally getting the boat in dry dock I was able to start restoring the finish. I wet sanded above the rub rail where the oxidation was the worst. On the hull I just used the Marine 31 Heavy cut. After only using the Marine 31 Heavy cut I was left with a pretty nice finish.
Here's a picture of the hull after only the Heavy cut.
-I edited in the red line to show the split from before the compounding and after.
After the final polish, sealant, and wax I'll upload all of the before and after pictures. I've done the interior, canvas, and vinyl already.
-Here's a 50/50 shot of the stainless spotlight. It was cleaned and then I used Collinite 850 Metal wax. Easy to use and works well.
More photos and the full writeup soon!
