Using a Cleanser to Clean Tires
dickwitham
Do any of you do this? I understand how strong of a cleaner this is, being that most have bleach in them (Ajax/Comet) and know that you have to be careful when cleaning around clear coated wheels, paint, etc. I have always found this to work exceptionally well on tires with white lettering. Typically I spray Wesley's Bleach White prior to using the cleanser just to loosen up.
I'm just curious if anybody else uses this technique and if anybody has discovered any major cons (besides it being so strong) when using it.
I myself haven't haven't and wouldn't use that. for tires themselves I use ARO ( amazing roll off) and wolfgangs tire and wheel cleaner. both of those are very good at getting dressing, and brown crud off from the tires. I'm sure others will let u know what they use. just my .02
:whs:
I use an APC 15:1 or S+R if i want to use a chemical.....i use steel wool if i need to get really dirty white letters clean instead of using a harsh chemical i just use that and a lil elbow grease
Megs APC+ here (typically at 4:1) and a good tire brush. I let the APC+ sit in the tires for a few minutes to let it do it's work than scrub the tire with the brush and rinse it off. comes out perfect and very clean all ready for your dressing of choice
Only thing about Comet is its VERY strong, and they recommend you use a lot of water with it to keep it from eating through what you are working on. So just be careful with it, if it is working for you and you like to use it... but I am not sure of the damages it can do to your wheels.
What about P21S Total Auto Wash?
I really liked the way that it removed some spots from an interior plastic surface and was considering picking up a liter of it (I had used a small sample bottle previously).
If I can also use the P21S for a tire cleaner in preparation for a fresh application of 303 Aerospace Protectant then I'll definitely look to make the purchase.
I haven't been into this new detailing obsession long now but I sure am accumulating numerous different products seemingly for each and every little aspect, so I'm really looking to find a product that can do a lot of things in order to cut down on extra unnecessary expenses.
A good tire cleaning product is one of those things I'd like to find a good multi-tasking product for.
I find Amazing Roll-Off works well or tires and rubber.
