No offense taken at all Francesco and I do appreciate the criticism. Guess it may seem as me trying to reinvent the the wheel. Just kinda a journal of my exploration in technique and trials. Maybe it will help someone else on their journey.
This is done partially for my own enjoyment in my spare time with products that I can hopefully use elsewhere if needed.
After I researched restoring headlights quite a bit because of a bad looking used headlight I bought. I did decide to use the 3M and two packs of assorted grit paper. After finishing mine, I started considering doing this as a side job and looking for quicker ways to get the same results before going any further.
Just seemed quite time consuming going through all the grits from 320 up 3000 and a bit unnecessary after more research.
To me, why not stop sanding at a much earlier point, ditch the fancy disks, and go to a compound if you can still get good results. Instead of repeated sanding and inspecting.
I do understand the more disks you buy the less they are. But, for someone like me, poor and just trying to get started, dropping 2-300 dollars (I assume your talking buying by the 100 to get to that price point) just on disks that I'm not even sure I'll get to use up is not acceptable to me, or my wife.
After my experimentation yesterday, I believe I see no need to buy any sanding disks. Just some wet/dry sheets in lower grits, compound, and polish. 1000 grit will be my limit for purchasing for now. I will continue to test and provide the results here.
I am interested in the durability of the 2k clears, but not having the proper spray equipment and the canned versions may only be used within short time frame per can once used, or you just got throw it out.
I shall continue on my journey, hopefully without blinders on. Anyone, please feel free to comment or call me a wanna be hack. Just provide the reason if you do.
