Using Iron X on wheels
lee1dew
I'm about to use Iron X on my wheels for the first time and had a couple of questions:
1. No need to worry about using it on factory brake calipers, right? As I understand it, it's aftermarket brake calipers with acrylic-based paint that I would need to worry about.
2. I've never seen a picture of Iron X being used on a wheel with the wheel weights taped off. Does anyone actually do this or does it not really matter? I've heard that it can turn the wheel weights green and that a little scrubbing will restore the original color. Is that true?
I read the same on the weights and will be covering mine.
Most wheel weights these days have a coating on them; I've never experienced any problem with discoloration.
Initially I taped off wheel weights but it's too time-consuming
Depends on the wheel weights...some are actually coated and you do not have to worry about exposed lead.
I avoid getting Iron-X on anything but the wheels...dabbing it on is quite effective and just be rather careful about your aim when spraying. A piece of cardboard can work as an effective backstop...fairly easy to use especially with the front wheels since they can be turned.
