Using ONR w/ wax leaving scratches
larryt1026
So am I the only one that had negative results with ONR? I used the ONR with wax one and used a spray bottle with the solution mixed with water and cleaned panel by panel with a bucket/grit guard/sheepskin mitt combo. So I sprayed the area I was going to wash, washed it and dried it. Pretty on par with everything I've researched. I ended up with minuscule scratches all over my paint...the ones you can only see very close to the paint and when the sun is out.
Now I've been just using it with two bucket system and rinsing the car before and after the wash. I have been thinking in order to save time and lessen possible water spots is to:
1. Rinse the whole car (with hose)
2. Spray whole car with ONR mixture (spray bottle)
3. Wash car with 2 bucket system (with ONR)
4. Spray whole car again with ONR mixture (no more rinsing)
5. Dry with microfiber weave towel
What I'm scared of is not rinsing after the wash. I am afraid that while dab drying the car, that it will leave scratches in paint if there were dirt left on the car.
What do you guys think? Thanks!
my first thought is ONR is typically associated with the Garry Dean method. If you do not know already, youtube "Garry Dean Method" and you'll see (spray, wipe, dry, buff). Also, typically people add a little ONR to their "normal" 2 bucket washes just for more lubricity in their normal washing shampoo.
i think here you've combined things in a way that made you do more work than necessary. IMO, if you're doing the 2 bucket method, stick with a dedicated car shampoo. Or if you want to do a rinseless (1 bucket), try the Garry Dean method.
Good luck.
i get scratches all the time there the wash love marks
ive given up i dont think its the onr or my method everytime i touch or look at my paint it just gets the love marks... but thats ok i just polish every 3 mths or so.
my car is infiniti g37 and is well known to have soft soft paint.
@ OP:
Have you ever used any "Rinseless-Wash" products other than Optimum's No Rinse Wash & Wax?
If so...
I'm wondering if they, too, left any scratches.
I can't even figure out what you're doing, it sounds like some sort of hybrid process.
First tell us how dirty your car is, what you are using for wash media and drying media, etc. and perhaps a bit about your technique (how many panels you are doing before rinsing the media, pressure used, etc.)
I get the feeling dirty wash/dry media is the culprit.
OP will need to inspect the wash/dry media often and rinse and/or replace it more often.
@ OP:
If so...
ive used Turtle Wax Rinse Free Wash and Wax and Meguiar's Ultimate wash and wax anywhere. If they don't scratch the paint, they WILL leave it feeling like sand paper. No b/s
That's a result that strays from the norm...Wonder why that is?
What kind of wash media are you using? Either stick with a traditional two bucket method or stick with rinseless.. No point trying to combine the two.
Feed back please
I've used like every waterless and Rinseless ever, never had this issue. Perhaps the car already did feel like crap?
I just watched the Garry Dean method. Maybe my microfibers are dirty...but I do not think it was. I clean them in the washing machine and dry them like all my clothes.
I am basically just wondering if I can rinse the car before performing the no rinse method..just to ensure I get as much debris off as possible. I will be rinsing with hard water..wish I had clean water.
So revised method would be:
1. Rinse car
2. spray ONR
3. wipe with microfiber in ONR solution
4. Dry
And of course it would be panel by panel.
1. Rinse car
2. spray ONR
4. Dry
If you already start with rinsing the car, why can't you rinse it again after washing it?
In your case, I would definitely check to make sure you wash and dry media/towels/mitts are clean, doesn't have lint or hair stuck to them, etc.
ONRWW will NOT cause scratches,dirt and/or debris WILL cause scratches.
So will some MF's on soft paint.
Are you air drying your microfibers or putting them in the dryer? Sometimes drying microfibers with heat will cause them to lose their effectiveness and cause scratches.
Really.. I dry my towels with heat once a week. Some are a year old and act and look brand new....so dunno
You can pressure wash the car or hose rinse the car before doing a rinseless wash. I do it all the time as a quick way to remove most of the dirt prior to working.
The issue you will have to deal with is the car will be wet with "hard" water while you are working and if it dried it may cause water spots if you are working outside.
There are a few ways around it. One is to use a DI water system like a CR Spotless, that's what I do. Another is to work inside or in a shelter. Another is to work at dawn or dusk when there is no sun.
You should not have to (or want to) rinse a car after a rinseless wash. The panel should be clean when you go to dry it. If you getting scratches something is not right. There area my wash procedures / techniques you can use, all of which will be "safe" if done correctly using high quality products and good technique.
I don't think you should have to polish out a car in a matter or months from wash induced marring. If so, something is not right in how you are washing it. You may get the occasional light mark here or there, which may or may not be avoidable. But if the whole car has fine scratches or swirls in a matter or a few months or a few washes, something is not right.
Sent from my iPhone using Tapatalk 2
Yeah that's what I am thinking. But the humidity in Florida is so high that even without the sun the water dries really fast. And I guess I need to start using dryer sheets on the MF towels. Time to get all new ones. This car detailing sure is a money pit lol.
never use dryer sheets with MF towels. they will basically be useless drying to soak up water. it will just push it around.
