Using Vinegar to remove water spots
Water Spots
s​
Vinegar
A common recommendation for removing water spots is to wipe the paint with vinegar, they kind you find in a kitchen pantry. If the water spots are in fact mineral deposits sitting on the top of the paint then this may work but you won't know until you try.
How Vinegar Works - (If and when it works)
Common cooking vinegar or food grade vinegar is a weak form of acetic acid, which is has low pH. Mineral deposits are just that, minerals that are either dissolved in water or embodied in water and when the water evaporates it leaves the physical mineral behind on the surface.
There are different types of minerals in water but one of the most common is Calcium Hydroxide. Calcium Hydroxide has a high pH, if the mineral deposits on your car's paint are Calcium Hydroxide, then the low pH Acetic Acid in the Vinegar will act to neutralize the high pH of the Calcium Hydroxide and either dissolve the minerals or break their bond to the paint and at that point you would be able to wipe them off the surface.
If the hard water spots are some other type of mineral deposits, then there's a good chance the acetic acid in the vinegar will have no effect and in a worse case scenario cause more harm than good. This is why in the forum world you'll often read accounts from some people where they share how great vinegar worked for them in their situation but then you'll read accounts by other people where the vinegar had no effect.
The problem with using Vinegar is that the acetic acid will act to remove any wax or paint sealant previously applied to the paint, wiping a waxed finish with vinegar certainly won't add more protection and what's the opposite of adding?
The other problem with using vinegar is that in and of itself it doesn't provide any extra lubricating ability outside of being a liquid. So using it with some type of cloth, for example a microfiber towel will not be as gentle as using a product formulated by a chemist specifically to be wiped over polished finish. And if fact if there are physical minerals on the surface then wiping them off without some type of added lubricity could in fact lead to scratching of the finish.
The two products show above, Duragloss 505 and Meguiar's M47 are manufactured by reputable companies and I'm confident the chemists have taken into account everything involved with creating a product for Joe Consumer to potentially wipe a clear coated finish to remove mineral deposits.
Remember clear coat paints are scratch-sensitive, that is they scratch easily. I think it's safe to assume that any product created by a reputable company for wiping off mineral deposits will include both lubricating agents plus glossing agents along with their proprietary ingredients for forcing the minerals to release their bond to the surface.
Key Benefits
The lubricating agents help prevent potential scratching from the minerals on the surface and the glossing agents restore a just detailed look to the finish.
These two included features to the products are important to car owners even thought most car owners probably don't even know they want and need these benefits from the product.
Vinegar offers neither of these benefits.
My recommendation
If you find you have what I call Type I Water Spots, that is what the world generically refers to as Hard Water Spots or Mineral Deposits, then obtain one of the two products listed in this article, especially if the spotting is an ongoing problem and give them a try. Other safe options would be to try a spray detailer, (at least it offers lubricating and glossing features), or try washing the car using a high lubricity car wash.
If you do opt to try vinegar, test first to a small area. Dampen a clean, soft microfiber towel with vinegar, place it on the affected area and allow it to remain for a few seconds so it can soften and hopefully dissolve the mineral deposits, then gently wipe the surface. This would be a safer approach then wiping dry paint with dry mineral deposits bonded to the surface.
Important
If you use vinegar to remove water spots, plan on re-applying some type of wax or paint sealant afterwards to restore any protection removed from the acetic acid.
Specialty products for removing "some" types of water spots
Meguiar's and Duragloss both make water spot removers that may work for Type I Water Spots.
Note: While Duragloss recommends their product for automotive finishes, Meguiar's only recommends their product for Marine and RV surfaces, so take this into consideration when choosing and using a product outside the manufactures recommendations.
I have successfully used M47 on automotive paints to remove mineral deposits but that does not mean it will work for you on your car for the type of mineral deposits or water spots on your car's finish. Always do a Test Spot and make sure you're getting the results you want and hope for.
Type I Water Spots = Topical
These are Mineral Deposits or what people commonly call "Hard Water Spots". It's the minerals in water that people are referring to when they use the word "hard" in the term "Hard Water Spots.
Type I Water Spots are primarily a mineral or dirt deposit laying on the surface of paint. Type I Water Spots can be the results of minerals suspended in city water or well water that are left behind after the water evaporates off the finish. This can happen by washing a car but not drying the water off the paint or if a sprinkler goes off next to the car covering the car with water drop that are not dried off the paint.
Type I Water Spots can also be dirt or pollution particles left behind after water from rain or inclement weather evaporates of the finish. Type I Water Spots can also be Type II Water Spots in that the water can leave both a deposit on the surface and an etching in the finish.
How To Remove
Type I Water Spots can usually be removed by washing or wiping the pant clean using a normal car wash, rinseless wash, waterless wash or spray detailer. There are also specialty products just for this including,
Specialty Products for removing water spots,
  • Duragloss 505 Water Spot Remover
  • Meguiar's M47 Marine-RV Hard Water Spot Remover
The first sentence in the product description on the back of the Duragloss label reads,
Formulated to easily remove water spots caused by impurities, (CALCIUM), in water.
Duragloss states it can be used for automotive finishes and it won't remove durable polishes. My guess is they are using the word "polishes" generically to mean waxes, paint sealants or coatings, not abrasive products used to remove swirls and scratches. Duragloss calls all their paint sealants polishes. See the chapter on polishes for more information.
The first sentence in the product description on the back of the Meguiar's label reads,
Specifically formulated to chemically break down and remove hard water Minerals off the surface.
When I worked for Meguiar's the common question about this product is can it be used on automotive paints and the company answer at that time was all the field testing was done on Marine surfaces in Marine environments.
My experienced guess is that it won't in and of itself harm a clear coat surface.
Two comments...
The average person doesn't know the difference between a topical mineral deposit, (Type I Water Spot), or a sub-surface etching, (Type II Water Spot), and the average Joe Consumer buying this product to use on a modern clear coat to try to remove Type II Water Spots would be let down as they don't understand you would have to abrade the paint with a compound to remove Type II, thus they designate a product like this to the Marine market. Just my guess.
Great article Mike. I use white vinegar/orange peel/ distilled water blend to wash windows with only.
I had a customer come by that had used vinegar on their paint and happy with the shine it made, BUT, when you touched it your finger did NOT GLIDE AT ALL. They were happy with the result but there is no protection left on the paint. Guess each to there own.:)
I've found Megs 105 to be the best all-around water spot remover. Chemical Guys Water Spot Remover works pretty good to, but stinks. I've found Vinegar to be pretty much good for nothing.
Water Spots are like a bad dream :(
Same here...I'm in the middle of a water spot nightmare on my black 2011 Dodge Challenger....it's taking a green cutting pad and 2 passes of M105 to remove them.....
I wasn't aware that normal household vinegar would strip most car waxes off the paint until Dr. David Ghodoussi shared that little tidbit with me...
I have seen legions of people recommend vinegar to others on detailing discussion forums for YEARS not also sharing this little tidbit of information.
That fact that it is very limited in they specific type of mineral deposit it will release the bond of is also a tidbit they leave out.
:xyxthumbs:
My goto for water spots (and also salt stains on carpets) is full strength vinegar with 1 ounce of ONR mixed in a 32 ounce bottle. The ONR acts as a lubricant both to protect the surface and make it easier for the salt to slide off the panel.
The way I adress it is to spray the water spots liberaly then cover with a microfiber towel and let the product act for about 5 minutes. Then I spray with a waterless solution (I use CarPro Ech2O) and wipe off. So far it has worked very well.
I have a bottle of CarPro Spotless and the results have been pretty bad.
If you get waterspots that is not removable with vinegar, Meguiars Wheel Brightener should take it all off without the need to let soak. The guys at the Rag company did a test with 4 products trying to remove water spots and I believe they used wheel acid on the 4th test, it's even harsher than Wheel Brightener but it was able to remove the spots easilly where all other 3 products were either failing or struggling.
:xyxthumbs:
Good to know. Only takes a minute to spray a sealant on the panel though.
I’ve had a few instances of hard water spots and I’ve always wound up using a light polish to remove them. I saw the Rag Companies video where they used wheel brightener to remove hard water spots and it made me cringe. I suppose it is causing less damage than a light polish, but it still scares me to spray that stuff on my paint.
I remember one of my Meguiar's co-workers back in 1989ish showing me this approach. I believe it's the hydrofluoric acid in the wheel brightener that removes "some" types of water spots.
Anyone telling someone else to use hydrofluoric acid in any form should also be warning them of the health risks if they get it on their skin, eyes or breathe into their lungs.
Acid works a treat on water spots and is the active ingredient in most water spot removers.
Vinegar (an acid) is the best choice due to a availability, cost and low health risk.
Sulfuric, hydrochloric and hydrofluric are extremely effective but vastly more dangerous. The latter being a form of acid almost all chemists shudder at the thought of. HF is horrendous stuff and should be avoided.
So as Mike mentioned, using wheel brightener is effective and a good choice if you have it, but breathing apparatus should be used to reduce exposure.
A qualifier is in order here ... in the case of many acids, whether or not they are "dangerous" depends on their concentration (by weight). Also, in most of these cases, the "dangerous" behavior associated usually refers to corrosivity, and that in turn depends on the acid's concentration. So, for example, low concentration hydrochloric or sulfuric acid can be safe to use, and conversely, high concentration acetic acid can be quite nasty.
Hydrofluoric acid is an exception as even at very low concentrations it is toxic, mainly due to the fact that the fluoride ion itself is toxic.
The worst stuff I ever had to deal with was fuming nitric acid in some of my organic chemistry labs ...
Solid qualifier.
Ergo: Everything is dangerous, it’s the quantity that counts.
I deliberately played it cautious with the information given.
HF is crazy stuff, calcium attack is no joke.
Why? Clearcoat is not vulnerable to acids. Also Wheel Brightener is not that acid. I can't remember who printed the numbers on the forum but it's PH was 5.5... hardly acid at all.
While I’m not thinking it’s not harmful, WB to me isn’t that strong. I am no ace in chemistry and still use gloves with it
There are many other production wheel acids that the smell alone will make you want to leave the room and punish brake dust much quicker
WB almost seems like a mild maintenance product when using it. It works yes but it’s not overwhelming by any stretch
