DFB
- Aug 12, 2019
- 4,970
- 3,117
I'm on annual leave from work for next two weeks, most of which will be spend detailing......BLISS!
The first project on the docket is the Mustang.
[FONT="]A full decontamination, polish and re-coating of an LSP, along with a few other tasks that I tend to do at the same time, is something I do every couple of years on my cars. I have been planning this project for a couple of months now and with rain predicted, starting today sort of made sense.[/FONT]
[FONT="]First job was a strip wash with a slightly higher pH soap used for more intensive cleaning or preparing for a task like today. I use my older foam cannon for this soap.
[/FONT]
[FONT="]Technically, the base layer of protection was Collinite 845, but who knows what else is on it now [/FONT]:laughing:[FONT="] . Either way, the contact wash knocked the life out of it.
[/FONT][FONT="]Next was iron decontamination using CarPro IronX. I also used the glove trick to massage the product in, which is a really good way to gauge what the paint feels like contamination wise. There was minimal color change from the IronX, which is to be expected on a well maintained car. Have I mentioned I hate using these sort of chemicals, they have a habit of sticking to your skin and the smell only leaves you once you have showered.
[/FONT]
[FONT="]After a thorough rinse, I decided to use a clay block on a couple of areas that felt a little rough, however I ended up doing the whole car. These clay blocks or towels are much easier to manage than a traditional clay bar. I'm using Meguiar's Final Inspection as the lubricant.
[/FONT]
[FONT="]A thorough final rinse before being brought into the garage and air dried. Any remaining water was then dried with a towel and Megs Final Inspection. I use Final Inspection for this task as it leaves nothing behind.[/FONT]
[FONT="]Now onto one of the more tedious tasks, masking up. I'm not particularly good at this so don't judge my work here. [/FONT]:laughing:
[FONT="]Up until now, everything I have done has been in preparation for polishing. Now for the main event. Nothing quite like brand new pads![/FONT]
[FONT="]The car had a few love marks here and there so I had originally planned to use CarPro Reflect as this it's a very easy to use product with minimal dusting. After doing a test spot it was evident I was going to need something a bit stronger. Another test spot revealed Sonax Perfect Finish was going to do the job I wanted.[/FONT]
[FONT="]This was my first use of Perfect Finish, I can now see why it's so loved.
The bulk of the work was done with the 5 and 3 inch machines, the Nano for the intricate stuff.
[/FONT]
[FONT="]The Nano was also used on the scratch prone gloss black rear decklid piece, Perfect Finish cleaned it up very well.[/FONT]
[FONT="]I can also attest that CarPro Eraser is better than NV Clarity which I started out using before switching to Eraser. Clarity seems to be quite a bit grabbier nor does it smell like the delightful Eraser.
[/FONT]
[FONT="]The glass also got some attention with a yellow Shine Mate pad with Perfect finish on the 3 inch machine.
[/FONT]
[FONT="]After the whole car was wiped down with Eraser, I went on to applying Gyeon Q2 Wax. I have mentioned many times I prefer to uses waxes and sealants, mainly because I like to chop and change my protection products. Gyeon make no claims of the longevity of this product which leads me to think it's not especially durable. However, the Mustang not being a daily and spending most of its time under a cover means that durability is not a big deal for this car. What I like about Q2 wax is the ease of application and extreme water repellency which mimics a ceramic coating.[/FONT]
[FONT="]While the bulk of the car was coated with the 5 inch machine and a black Lake Country SDO pad, the smaller areas I used a foam applicator pad.[/FONT]
[FONT="]Q2 Wax must be left for 30 minutes before buffing, [/FONT][FONT="]allowing time for a general clean up of the equipment used, including rinsing and soaking the pads in Microfiber Cleaner.
[/FONT]
[FONT="]Onto the final buff, the best bit!
[/FONT]
Race Red is a flat, non-metallic paint. While it doesn't pop like a metallic would, it certainly glows after all this work.
[FONT="]The paint turned out very good but there are still a few things to attend to tomorrow though. I'm not happy with the glass and it will need more attention before applying a sealant. I also want to dress all of the trim with CarPro Reload to help maintain the DLUX I applied a while ago.[/FONT]
[FONT="]More to come..........[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
