Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Video: Mark your backing plate to make it easy to see pad rotation
Here's a quick video that show how and why to mark your backing plate to see and monitor pad rotation while doing any correction or polishing steps.
5" Backing Plate
Lake Country 5" DA Backing Plate <-- Get this one as the Velcro will match Lake Country Pads
The 5" Lake Country Backing Plates fits all popular dual action polishers including Porter Cable, Griot's Garage and Meguiar's.
Lake Country
5.5" Flat Pads
In order from the most to the least aggressive
Yellow = Cutting pad (most aggressive)
Orange = Light Cutting Pad
White = Polishing Pad
Black = Finishing Pad
Blue = Waxing Pad (softest)
The outer edge of the face of these pads is tapered so they are actually a little under 5" in diameter
Approximately 7/8" thick
Still working by hand?
If you need a dual action polisher, the Porter Cable 7424XP is a quality tool from Porter Cable and the tool that started the DA Polisher craze.
Here's the link to get your own Porter Cable 7424XP
Porter Cable 7424XP Dual Action Polisher
If you have not read this and you're new to machine polishing... read it!
DA Polisher Trouble Shooting Guide
DON'T LOOSE THE COMPRESSION WASHER!
The Compression Washer
For professional results, get Pinnacle compounds and polishes. This is the line of products I use on a lot of the show cars I work on and it's also the line of products I switched Wayne Carini's shop over to at F40.com
Pinnacle Advanced Compound
Pinnacle Advanced Finishing Polish
Pinnacle Liquid Souveran Car Wax
Pinnacle Ultra Poly Clay
Pinnacle Clay Lubricant
Super Soft Deluxe Green Microfiber Towels with Rolled Edges - 6 Pack
Pinnacle Crystal Mist Detail Spray
(This is the product you use to maintain the results)
Get a copy of my how-to book, comes in three options....
Detailing How-To Book and Detailing How-To E-book by Mike Phillips
Here are the links to get the paperback and e-book versions of the second edition of my detailing how-to book.
Mike Phillips’ The Complete Guide to a Show Car Shine Paperback Book
For those that want the e-book verson...
Mike Phillips’ The Complete Guide to a Show Car Shine E-book Download
You're going to need to learn this....
How to clean your foam pad on the fly
Get head knowledge first and then go out into your garage...
How to Properly Use the Porter Cable 7424XP Dual Action Polisher Updated!
Also see these videos...
Video: How to remove shallow RIDS and how to machine apply both a paint sealant and a finishing wax
Video: How to buff tight areas plus concave and convex curved panels by machine
Video: Tips for using a Rotary Buffer and the Flex 3401 on vertical panels
:buffing:
5" Backing Plate
Lake Country
5.5" Flat Pads
:buffing:
