Video Review: McKee's 37 Tire & Rubber Rejuvenator | Cleaning Your Tires Without Rinsing
Joe@NextLevelDetail
How's It going guys, In the video I display how nice, Tire & Rubber Rejuvenator plays with rinseless washes when you have no hose or water access.
what makes Tire & Rubber Rejuvenator different than others is, It is actually hydrating your tire every time you use it. It is not stripping your antiozonants.
Antiozonants is what keeps your tire from cracking, And using harmful powerful cleaners actually strips and degrades your antiozonants with every use. If you ever used powerful and inexpensive degreaser/all purpose cleaner on your tires you will notice how they look grey dry and thirsty. those chemicals are stripping and harming your tires with every use.
Tire & Rubber Rejuvenator cleans and hydrates your tires with every use, If you pay attention in the video you will notice how they look rich and black, Almost like they are dressed.
That's gotta be one of the best-kept secrets of the detailing industry, that you can use that product without rinsing. It's not mentioned anywhere on the product page. Thanks for letting us know there's another product that can be used this way other than Mothers Back to Black Tire Renew.
Well done video. Great information.
Thanks Mike!
Thanks , im glad you enjoyed.
And yes its a really useful tip, I have used it quite a few times on my mobile details with no water access. Nice to know that its hydrating your tire when you wipe it away and not causing damage.
Sent from my SM-N920V using Autogeekonline mobile app
Great video my man! I have the gel and love it! I will have to get the Rujuvenator especially when doing RW's in winter here. I have been using N-914 on them now which is working amazing at a presoak dilution.
Do you wash and reuse your microfiber towel? I buy a big bag of these small cheap terry towels and throw them away after doing a couple tires.
Thanks Jeremy!
The Tire Gloss is good stuff, The Tire Cleaner is a rinseless washes dream. Some people do rinseless washes by choice, Others by force. And cleaning wheels/tires with no water can be tricky.
Great video Joe. Looks like a winner!
Thanks Si.
Nice video.
Thank you!
I Usually wash my dirty rags by hand in a bucket, They are not even worth putting in my washer/dryer as they leave all that dirty and grime behind. If i do have a larger load I will go to a local laundromat and wash them there.
How many tires are you seeing out of the 16 oz bottle? I tried it last night but after 2 tires I was almost out.
Sent from my Pixel using Autogeekonline mobile app
Woah, That's alot. With Tire & Rubber RJVNTR not alot of product is needed. Spray the face of the tire agitate with a brush. And even if using a hose I would highly recommend getting a microfiber towel and wiping the tire to remove browning/dirt.
Tire & Rubber Rejuvenator is different than the harmful tire cleaners that we are accustomed to using. even with 1 spray application it softens and lifts the dirt so you can come with a hose/towel to wipe it away from the tire.
Try those tips for next time.
Tire & Rubber Rejuvenator is 1 of those products that's really strict on following its directions to the T... Once you use it exactly as directed you see the intended results + don't use quite as much as your 1st time with it.
It's best to spray onto a Dry tire, scrub 1st time with minimally damp brush, rinse brush, wring brush, scrub again, rinse brush this time leaving it wet and scrub again, now spray tire once more, rinse brush and wring it out, scrub, rinse brush and leave wet, scrub again and the water in the brush will create suds...
You'll begin to get the hang of it. The key is to try not to rinse the tire off with the hose for as long as possible. If the tire's not super dirty you can hold off rinsing it until you're done. [you're done when your brush rinses clear] But you may want to go an extra step if you're striving for perfection.
I hadn't seen Joe's post until now... That's another way of going about it. Good advice.
Thanks Joe! That kit just arrived on my doorstep yesterday. The timing of the video was perfect. I'm looking forward to the next video.
Thanks for the heads up. Nice work.
Sent from my SM-G900V using Tapatalk
Thanks Jeremy!
yeah I used to much then, I sprayed on until the whole tire was wet, used a wet brush to scrub, rinsed brush and repeated about 3 times as the tires still looked brown and then rinsed with a hose.
If you used less, I'm sure your results would have been even worse. I don't see how using too much of a product like this would give lesser results.
Hey Cruz, If you still seen "brown" on the tire you might have been dealing with "blooming" this happens when the antiozonant in the tires has failed, This is due to using aggressive and harmful chemicals to clean tires. With every use you are stripping the antiozonant from the tires with harmful degreasers and tire cleaners. and the antiozonants are placed in your tires to prevent, cracking, drying out, Once the antiozonant is stripped and comes in contact with the ozone in the air. It will start to turn brown. This is more than likely what you were experiencing and it will not get clean.
Have you ever noticed using harsh tire cleaners, That no matter how much you spray and agitate you kind of always see brown? That is stripping the antiozonants in the tires. That is why Tire & Rubber Rejuvenator is different, It is hydrating your tire with every use not stripping. That is why you can wipe off the tire cleaner and do not have to rinse.
Lol, This gave me a laugh WRAPT, and I could not agree more with you, I think he was experiencing blooming, I typed about it above.
Surely if he used nearly a whole bottle and still seen brown on the tires it has to be blooming.
I personally don't even really clean my own tires, if I do it's normally just with Uber rinseless or d114. I was planning a how to/review but it didn't really come out as I expected and wasn't sure if it was used error or not
Here's how it lookedView attachment 55669View attachment 55670View attachment 55671View attachment 55672View attachment 55673View attachment 55674
Hey Cruz! Thank's for posting the pics.
The pictures you have posted seem to be the tire has "bloomed"
The browning that you still see may very much be what I explained in the post above.
Is this the first time you have noticed this? is this on your personal car?
have you been using strong tire cleaners to maintain them? if it is your vehicle.
It's on my personal car and like I said I normally don't even wash the tires and when I do it's just with whatever waterless I'm using at the time but normally it's Uber rinseless or d114
