Waffle-style foam buffing pads also allow forWhen you apply pressure with the waffle, you compress it and much more than 50 percent is making contact with the paint.
Your not suppose to only using the weight of the machine when polishing...
I won't go that far.With that said, I wouldn't use them for Jeweling.
heat build-up to have escape routes.
3M's Perfect-It Ultrafine Foam Polishing Pads are
used for "jeweling"...and they're "waffle-style".
I agree, I still swear by LC flat pads and Rupes pads, I just bought some Buff and Shine flat pads, haven't used them yet. The other thing I don't like about waffle, ccs or hexlogic is product migrates to the cracks and gaps and goes to waste.
When you apply pressure with the waffle, you compress it and much more than 50 percent is making contact with the paint. Your not suppose to only using the weight of the machine when polishing...
yeah. I have to dot the polish on the high spots of the pad.
Because the waffles are cut too deep, you would have to press very hard to get the full pad to touch the paint, and that would bog down the DA motor.
Not good.
Ok, I pushed the waffle foam on a piece of glass, and it's 67 percent contact.
Any more pressure and the foam probably wouldn't rotate.
How did you measure the surface contact?
I eyeballed it by looking on the other side of the glass, while putting about 10 lbs pressure.
But upon actual calculation of the dimpled areas and subtracting from the overall area, I overestimated, and it's about 60 percent +/- contact.
I'm willing to give it a few more chances since that 3M waffle has gotten such good user reviews.
My waffle pad is a cutting pad, so it's a lot stiffer and hard to get full contact.
On a softer pad, you can compress it easily and get 100% contact.
