Real Riders
- Jul 18, 2013
- 749
I hand wash and dry dealer lots and it takes me 20 minutes per car. I use a sheepskin synthetic wash mitt and a Water Sprite.
Here's everything I used except for some quick changes for the hose fittings and a dedicated water sprayer for rinsing the car.
Ready to put the top down and go for a cruise here in sunny, Stuart Florida!
:dblthumb2:
The QR hose connectors & valve Mike uses are real timesavers for me. I smear a little silicone grease on the threads to make sure the fittings don't corrode.Interesting, so you washed without any buckets, and just one mitt? I assume you use the foam gun to rinse the mitt out after each panel?
Was that mitt also used for the face of the wheels or you did the wheels just with the one brush?
I'm looking to speed up my weekly maintenance wash take currently takes me 1.5-3hrs (yes I know stick with what works but...)
I'd be interested to see how you break down your time.
For example, when I wash my 09 Jeep SRT8 here's my timeline for my weekly maintenance wash:
5-10 minutes to get set up
5-10 minutes to pre-soak my car with a foam cannon on dry paint (sometimes I skip this step and forgo the pressure washer altogether)
20-30 minutes to wash the wheels (barrels first with a Wheel Woolie, then tires with a brush, followed by the lugs with a BHB, and the face of the wheels with a wash mitt)
5-10 minutes to rinse the dirt and soap and dry my wheels (to prevent spotting on the finish)
20-30 minutes to two bucket wash (that's working as fast as I can, it's got a lot of surface area to cover)
5 minutes for final flood rinse
15-20 minutes to dry with WW towels w/ a drying aid (currently WG Uber, love that gloss)
2.5-10 minutes to apply dressing to trim and tires
7.5-15 minutes to clean the glass and mirrors
5-10 minutes to put everything back away
That gives me a base time anywhere from 1.5hrs to 2.5hrs for a weekly wash and I just don't see how I could be done faster other than skipping steps which I do, do from time to time, but still I'm looking at 1hr minium. I'm still apprehensive about WW'es (worried about marring the paint) and have done a few within 10-20mintues when I pressed for time but find it's less than perfect (lots of things get skipped).
It gets way too dirty for WW or RW on a weekly basis IMHO:
Weekly wash in progress:
Thanks!
Do you have any tips for cleaning the undercarriage?
No doubt that's the biggest time saver. I used to have free access to a brushless auto-wash, and I relied on it far too much, leading to neglected finishes. After correcting the paint recently, I've found that I can hand wash & dry my cars easily, with better results than I could ever get at the drive-thru. I'd forgotten how much I enjoyed the process, the cars definitely look better, and the paint will last longer.First - I don't normally ever let my vehicles get real dirty thus they are quick and easy to wash to start with.
I thought of another possible benefit to using a cart.
I find myself running back & forth to put the hose nozzle somewhere out of the way, and rinsing any debris off of my hand after handling it. A cart user could rest the nozzle on top or hook it to the side of the cart, right where it's needed and without risk of contamination.
Maybe I need to find room for a cart.
