Edit: I know typically one would use a more plush towel that what was used above for rinseless washes.
I like this one. It is soft and rinses out well.
Ultra Soft Microfiber Rinseless Wash Mitt
Just realized yesterday after testing two rinseless washes side by side how much of difference your wash media makes. I usually do them with my mitt, but did not have two of the same mitts to test with so I used some semi-plush paint towels. While using the towel method I noticed that neither rinseless seemed very slick on the paint. I was testing them just on the hood and fenders. When I went to wash the rest of the vehicle I decided to use my mitt.
What a big difference, it was much much slicker on the paint. So I tried it with just the plush side of a Gold Plush Jr to see if a better towel made a difference and it was as grabby as it was with the lesser microfiber. Then I tried it with a micro-chenille wash mitt and I was about as slick as the rinseless wash mitt.
^That depends on your definition of safe and your wash method/technique.
I occasionally use a cheap micro-chenille wash mitt with rinseless on the very bottom of lower body panels/bumpers. Mine does not hold much solution so I put a grout sponge in it. I don't like it much for rinseless, it seems better suited for a traditional wash. A higher quality one may work better than mine.
I've been using a rinse less wash since my garage walls are made of drywall. I wanted to know what is a good wash mitt for a rinse less wash?
This is the mitt that I have right now. Didn't know if I needed to purchase the recommended rinseless wash mitt or to use 10 microfiber towels.
Thanks for the input. Last question, can I perform the rinseless wash with super plush microfiber towels or does it have to be a "Rinseless wash towel"?
I use 16" x 16" Eagle Edgeless Korean 70/30 Super Plush 480gsm Microfiber Detailing Towels. They soak up and hold a TON of solution and are slick as can be over the surface. Lots of long fibers that do an excellent job of holding onto the dirt. I fold them to create 16 fresh clean surfaces when using a single bucket method.
They work great. I been using Rinseless with that technique on my S4 since last fall with no issues.
