Al-53 said:just use dish soap on them..it will clean them....if it cuts grease on pots and pans it will clean your pads...Dawn is a dish soap here in the US....and work fine cleaning pads.....
APC is a all purpose cleaner...
even a citrus cleaner works....
Al
I'm going to try this the next time I use Collinite. I always have a heck of a time getting it out of the applicator.Al-53 said:Nica...I use LA awesome APC....I use it full strength..I spray it on...let it set a few minutes and then throw in the machine....you can try a 3:1 with the Megs you have....if you do them by hand Nica...spray...let sit a few and then wash with dawn....I have cut Collinite this way and pads are clean....
I use LC pads and I haver never had a problem using Dawn.LazerRed1 said:I always use a pad cleaner then finish off with Dawn. Anyone had a problem using Dawn?
LazerRed1 said:I saw this warning on a site where I just purchased some LC CCS pads.
WARNING: Never clean foam pads or soak foam pads in dishwashing soap (Dawn) or laundry detergents. These detergents will attack the glue that holds the Hook and Loop backing material. Soak pads in a car wash shampoo or use ************** Pad Cleaning Powder.
