Whitewater25
Member
- Feb 14, 2015
- 618
I have a bucket of microfiber towels soaking in 3D towel Kleen overnight to wash tomorrow,I will dry them on low heat but which temp do you all find is best for the wash cycle?
I wash them warm, based on a few things I read and saw on the web. Mostly based on the Junkman2000's microfiber towel washing video. What it comes down to is, How hot is hot?. At 140F, the polyamide (one of the components of the "microfiberstarts to melt. Some hot water can get that hot, especially in laundromats. So the idea is to get the microfiber as hot as possible, while not having any melting going on. Hence, warm. I air dry, but the video did say that you could put them in a dryer on cool, or air dry only. I don't want to have to deal with the effects of dryer sheet residues, so I air dry after they come out of the washer.
Did the hang dry for years but really is not necessary, actually made the thicker towels stiff.
I'm with Mantligh, hot and high.
This information is just false. I don't know why TRC keeps pushing this false data, I had seen them do it through Yvan at OPT, and apparently through the Junkman also. Here's a chart of melting points in degrees C: Polyamide plays an important role in automotive, electronic and packaging . The lowest melting temperature is 352 F.
I'm not sure which polyamide grade is commonly used for MF towels, but even if you look at the heat distortion temperature the lowest temperature, converted to degrees F, is 239. And if you look at Nylon 6, or 6,6, which are the most common and what I would suspect towels are made of, that heat distortion is temp is 338 and 437 F, while the melting temps are 431 and 500 F.
Yeah, 140° melting point... it gets hotter than that in our vehicles in the summer time just sitting in the sun. I've not had a towel melt in the glove box. Yet.
Basic question to be asked remains: What improvement are you getting by washing microfiber towels at hot vs. warm?
